Brake upgrade
Old Jul 23, 2008 | 05:19 PM
smithjr's Avatar
smithjr
Default Brake upgrade
To update my c5 to c6 brakes .I can get rotors calipers and pads from my local GM dealer for 1500.00. Do I need different brake lines or different master cylinder? If so what kind and where can I get them.
Old Jul 23, 2008 | 05:38 PM
Bill Dearborn's Avatar
Bill Dearborn
Are you talking about the C6 or the C6Z brakes? The C6 brakes use the same calipers the C5 uses.
Bill
Old Jul 23, 2008 | 05:48 PM
smithjr's Avatar
smithjr
sorry C6Z.
Old Jul 23, 2008 | 05:55 PM
RC45's Avatar
RC45
Be aware you are adding 11lbs per wheel up front if you go with stock GM C6 Z06 rotors.
Stock C5 Z rotors weigh 18lbs each, C6 Z)6 rotors weigh 27lbs each.
The master will work, you need a longer brake line for each caliper, so you may as well switch to stainless steel lines at the same time.
You will wheels that will clear the wider calipers up front.
Old Jul 23, 2008 | 07:28 PM
smithjr's Avatar
smithjr
Default rotors
any suggestions on rotors? and where do i get brake lines. the front weigh more how about the back?
Old Jul 25, 2008 | 12:03 PM
smithjr's Avatar
smithjr
Default Suggestions
Ppoint me in the right direction.
To Brake upgrade
