Tire Sensor
Old Jul 24, 2008 | 12:47 AM
99vet's Avatar
99vet
St. Jude Donor '12-'13-'14
Default Tire Sensor
Can the battery be replaced with out removing the tire from the rim?
Old Jul 24, 2008 | 01:19 AM
lucky99's Avatar
lucky99
no you will have to dismount the tire. there are some good DIY threads out there
Old Jul 24, 2008 | 01:29 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
And replacing the battery isnt the easiest thing either...do a search on that, theres a good thread.
Old Jul 24, 2008 | 02:02 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
http://forums.corvetteforum.com/show...lace=batteries
Old Jul 24, 2008 | 02:42 AM
Corvette Don's Avatar
Corvette Don
Its not easy to do, I suggest you get a broke/cracked sensor to try on first.
Old Jul 24, 2008 | 03:47 AM
white90conv's Avatar
white90conv
I do not have runflats and could easily replace the sensor only breaking the outer bead loose. This is less work than removing the tire and does not mess up the balance. I have had minimal success replacing the battery in the sensor. It only worked on one out of four I tried.
To Tire Sensor
