Check engine light-P0103 code
Old Jul 24, 2008 | 01:22 AM
bdiddo's Avatar
bdiddo
Default Check engine light-P0103 code
Need help! I have had the "check engine" light on for some time. Now it's time to get the sniff test (emissons inspection). The only code I'm getting is the P0103. So, I just replaced the MAF tonight thinking and hoping that was it. Code is still there.
what else can I can check?
Old Jul 24, 2008 | 10:40 PM
bdiddo's Avatar
bdiddo
Old Jul 24, 2008 | 11:39 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Not to offend but you did clear the codes, right?
Old Jul 26, 2008 | 01:40 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
You are on the right track. Here is the diagnostic info for P0103 on a 2001.
GL!
Old Jul 26, 2008 | 06:47 PM
bdiddo's Avatar
bdiddo
No offense taken...you would not believe some of the knuclehead things I done in the past but yes I did clear it.
as stated, i have replaced the MAF. my next step is to check all the pcm connections and then ???? Could this be related to the connection? don't know how to check that though. Any comments would be appreciated
Old Jul 26, 2008 | 06:54 PM
dougbfresh's Avatar
dougbfresh
Why did you replace the MAF to begin with?
Old Jul 27, 2008 | 03:22 AM
bdiddo's Avatar
bdiddo
following the diagnostics, it appears the the maf was shot.
do you have any suggestios?
Old Jul 27, 2008 | 03:24 AM
50_Dave's Avatar
50_Dave
check the connector. I had the same problem with mine and we had to repin the connector as it was bad. You could wiggle the wires around and they were not in there correctly. Try it out.
Old Jul 27, 2008 | 01:53 PM
bdiddo's Avatar
bdiddo
Thanks...
I'll check it out and let you know
To Check engine light-P0103 code
