which heads??
Old Jul 24, 2008 | 10:19 PM
q8_c5's Avatar
q8_c5
Default which heads??
which heads guys do you recommened to use with TSP 233/239, .595"/.603"cam..my m6 c5 put down 410rwhp with that cam packege,,u/d pully and bolts on....i am searching for the perfect heads which will work very well and preduce a great tourqe and power with that cam..and what do you think guys the aprox. rwhp after doing the heads swap??
thanks
Old Jul 25, 2008 | 09:54 AM
RBChallenger's Avatar
RBChallenger
Cant speak for the heads.. but I have to say that I personally like those numbers for a cam only car!!! Sounds like a good setup you have going there.
Old Jul 25, 2008 | 09:58 AM
nickolbag's Avatar
nickolbag
Cartek does good work with heads.
Old Jul 25, 2008 | 10:20 AM
black98c5's Avatar
black98c5
The question here is, how much are you willing to spend? Sky is the limit. You can go with some budget heads ($1200) or go with aftermarket casting like AFR or TrickFlow ($2200+).
Old Jul 25, 2008 | 10:41 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
thanks
^^If you are still running the stock LS1 heads, you should gain at least 40 rwhp with a set of good after-market heads. For budget heads try some ported & polished Patriot 243s, or on the more expensive side take a look at AFRs.
Old Jul 25, 2008 | 10:54 AM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
By "bolt ons" I assume you already have headers... but intake and TB?
My vote is AFR. I went up there (factory is right up the street from me) and Tony showed us around. Although they produce quite a few heads/models, each one is carefully machined, checked, inspected, and tested. The final numbers show they flow more, the quality of the shop is one reason why.
My buddy here at work bought a set and Tony hand ported them. His 'old school' 383 gen 1 is making over 500 hp.
Old Jul 25, 2008 | 06:15 PM
q8_c5's Avatar
q8_c5
thanks man,,i forgot to say that the stock intake and tb are ported and the guys at katech did really nice job with their tune
Old Jul 25, 2008 | 06:33 PM
q8_c5's Avatar
q8_c5
with their h/c packege your are 100% right..but i dont know how well it work with other after market cam
Old Jul 25, 2008 | 10:57 PM
nickolbag's Avatar
nickolbag
I wouldn't know either. All the guys I know running their H/C setups have Cartek spec out everything, but they sure do fly. You can always call and see what they think. They would know better than us
Old Jul 26, 2008 | 11:48 AM
q8_c5's Avatar
q8_c5
i will thanks for replay
Old Jul 26, 2008 | 12:35 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
AFR 205s are the perfect heads.
Old Jul 26, 2008 | 12:48 PM
q8_c5's Avatar
q8_c5
it seem i will go with AFRs
but i am wondering whats the max mill i can do (what cc) with out flycuting the pistons..with the use of .04 comiteck gasket??
and what the extra Rwhp should i expect from the heads??
Old Jul 26, 2008 | 03:37 PM
q8_c5's Avatar
q8_c5
i need help guys with my last 2 quistions??
Old Jul 26, 2008 | 05:30 PM
Corvette Don's Avatar
Corvette Don
You will have to call AFR but I am going to say 63cc is the limit if you are using .040 gaskets. You will need to check ptvc either way.
Old Jul 26, 2008 | 07:14 PM
q8_c5's Avatar
q8_c5
thanks for this info man so for sure i will be safe with 62cc with gm gaket..thanks again
Old Jul 26, 2008 | 07:51 PM
Corvette Don
Yes I am pretty sure 62cc and a stock gasket you will be fine
Old Jul 26, 2008 | 09:59 PM
savage1's Avatar
savage1
AFR Heads would relly compliment your mod.
and you wont need to buy rockers and springs
I added them with a mild cam 224/228 LSA 114 .581/.588
and some LG pros and I'm pulling 450 RWHP
savage
Old Jul 27, 2008 | 08:26 AM
q8_c5's Avatar
q8_c5
savage
I sow your sig great numbers man
To which heads??
