Replacing hood light
Old Jul 25, 2008 | 11:36 AM
Raven Bob's Avatar
Raven Bob
Default Replacing hood light
I,m not much of a mechanic but I thought this would be simple. How do I get the old hood light off? It doesn,t have screws but has something that looks like a thumb tack with a small hole in it. Any help would be appreciated
Old Jul 25, 2008 | 11:47 AM
87SAM's Avatar
87SAM
From the 200 manual:
Underhood Lamp Bulb Replacement
Removal Procedure
Remove the underhood lamp lens cover. Grasp the lens cover and depress the upper and lower locking tabs to release.
Remove the bulb from the underhood lamp. Gently grasp the bulb, lift the bulb to release tension, then swing the top edge of the bulb away from the connector.
Installation Procedure
Install the bulb to the underhood lamp. Gently grasp the bulb, connect the lower edge of the bulb onto the lower connector, lift the bulb, then swing the top edge of the bulb onto the upper connector.
Install the underhood lamp lens cover. Snap the lens cover locking tabs into place.
Old Jul 25, 2008 | 03:01 PM
Raven Bob's Avatar
Raven Bob
Thanks, but I need to replace the entire assembly.
Old Jul 25, 2008 | 04:34 PM
87SAM's Avatar
87SAM
Not as easily,
Underhood Lamp Replacement
Removal Procedure
Open the hood.
Disconnect the electrical connector from the underhood lamp assembly.
Caution
Wear safety glasses in order to avoid eye damage.
Drill out the 2 rivets retaining the underhood lamp assembly.
Remove the underhood lamp from the vehicle.
Position the underhood lamp to the hood.
Rivet the lamp to the hood.
Connect the electrical connector to the lamp.
Close the hood.
Old Jul 25, 2008 | 07:47 PM
Raven Bob's Avatar
Raven Bob
Thanks again, I'll give it a try.
Old Jul 26, 2008 | 01:28 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I wonder if you could find small plastic "push" pins instead of rivets? The kind that the hood pad is held on with?
To Replacing hood light
