Help with Reverse Lights...
Old Dec 29, 2001 | 05:42 PM
GTXgp's Avatar
GTXgp
Default Help with Reverse Lights...
Need some help, when I'm in reverse, the reverse lights aren't coming on. Anyone had this problem? Any ideas?
Thanks,
Adam G
Old Dec 29, 2001 | 05:52 PM
LoneStarFRC's Avatar
LoneStarFRC
Default Re: Help with Reverse Lights... (GTXgp)
Yup, I had this problem within the first year. Had dealer take care of it. He said they "replaced" the back-up light switch. Doubtful. Probably just re-secured a loose connection. Dealers do this kind of thing to GM all the time.
Jack up your car and take a look to see if the connector is loose or off of the switch on the trans. If so just re-connect it. Otherwise let dealer check it. :cheers:
[Modified by Tx99FRC, 3:52 PM 12/29/2001]
Old Dec 29, 2001 | 07:35 PM
GTXgp's Avatar
GTXgp
Default Re: Help with Reverse Lights... (Tx99FRC)
Thanks, I'll have to check that out :cheers:
Adam
Old Dec 29, 2001 | 09:58 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
If you have an M6 faulty back-up light switches are common,a loose connection to the switch is not common :p:
Old Dec 30, 2001 | 01:10 PM
dbrogan's Avatar
dbrogan
Default Re: Help with Reverse Lights... (C-5 TECH)
I have this problem on my '99 manual transmission. It comes and goes and I haven't seen it recently (though it's hard to spot unless you're looking for it). I don't think it's anything as simple as a loose connection based on how sporadically the problem comes and goes. When I notice the lights fail to come on, I repeatedly switch in and out of reverse two or three times. They
eventually come on, though little if anything would have wiggled the connections.
-Dave
To Help with Reverse Lights...
