Headlight pop-up problem
Old Jul 27, 2008 | 12:22 PM
Tom Porter's Avatar
Tom Porter
Default Headlight pop-up problem
Every once in a while my headlights wont pop up. I have to turn the lights on a few times before they pop up. What is the cause of this?
Old Jul 27, 2008 | 12:32 PM
UncleFodder's Avatar
UncleFodder
Do you have stock headlight bulbs or HID's? Do you hear a grinding noise when you lower the headlights?
Old Jul 27, 2008 | 04:19 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
If you have a stock headlamp setup, there are two possibilities. One is the headlamp switch and the second is the headlamp controller. First guess here is the switch is bad. Are the headlamps actually on, but not up? If so, then its the headlamp controller itself. If they aren't on, then the switch is probably bad.
To Headlight pop-up problem
