Remote Bleeder
Old Jul 28, 2008 | 10:16 AM
vortecblazer4wd's Avatar
vortecblazer4wd
Cruising
Default Remote Bleeder
Question about installing a remote bleeder for the clutch. Do you have to have the torque tube down to install this, or are you able to install it just removing the tunnel plate? Want to bleed my clutch out, but wasn't sure if you can add this bleeder withough removing torque tube.
Old Jul 28, 2008 | 10:37 AM
BlackZ06's Avatar
BlackZ06
The remote bleeder is installed to the slave cylinder. You will need to remove the Torque Tube to expose the clutch assembly in order to install the part.
Old Jul 28, 2008 | 11:26 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Old Jul 28, 2008 | 01:27 PM
rockgoped's Avatar
rockgoped
To Remote Bleeder
