What are some good, easily available hi-temp paints? Spray paints?
Rustoleum used to have a High-Temp Sunrise Red I thought, but I can't find the high-temp version of it anymore... Or did they make a high-temp clear coat??
Any reccs? Going to tape up the pad and paint the, uhh, external casing part. Thx!
I painted mine with Dupli-Color Hi-Temp Engine paint available from O'Reilly. :cheers:
-Jeremy
-Jeremy
darkmercury
close
- Member SinceFeb 2001
- LocationHouston TX
Liked:73 Times in 46 Posts
I used 1200 degree Duplicolor which looks Satin finished... but they have a high temp CLEARCOAT spray in the 500 degree selection.
-Jeremy
Same here, you can also get it at Kragen Auto Parts! Worked fine for me, but be sure to prep them well and remove all brake fluid.I painted mine with Dupli-Color Hi-Temp Engine paint available from O'Reilly. :cheers:
-Jeremy
I just used Rustoleum and it worked fine.Been on the car for 2 years.
I used VHT Brake Caliper Spray # SP-731 Racing Red...They have
a ton of other colors too. Good for 900F/490C temps and is chemical
resistent. Car Parts (NJ) has them on the shelf...Cost ~ $4.00/11oz. can.
Here's mine...GeorgeC
http://users.rcn.com/georgec/Red2.htm
