X pipe Info / opinions
Old Jul 29, 2008 | 12:03 AM
klammer76's Avatar
klammer76
Default X pipe Info / opinions
As some may have read in an earlier post of mine, I have had a problem with my 98 coupe's exhaust welds breaking repeatedly. I am now considering installing an after market X pipe for better welds and construction. I am looking for opinions on the various X pipes (Corsa, Borla, Bassani) from people that have them. Fit & finish, installation, price and were you satisfied with the product. I seem to be leaning toward the Corsa at this point but am open to all.
Thanks,
Klammer
Old Jul 29, 2008 | 12:41 AM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Before I went with the LG Street Headers, I had a Bassani X-Pipe, stock headers/cats, and Z06-TI's at the back, didn't have any problem at all. Bought the Bassani used from a forum member, I believe $135. there about.
Old Jul 29, 2008 | 02:26 AM
Bluefire's Avatar
Bluefire
Just a thought...
Try loosening all of the headers bolts. They might be cocked with respect to each other. The combination of that, with acceleration stress rocking the engine, could be snapping the welds. Is the H-pipe hard mounted or attached with a rubber insulator?
Old Jul 29, 2008 | 10:15 AM
klammer76's Avatar
klammer76
I will check the mounts when I get home this weekend. It has been about 4 years or so since I have had the H pipe off. I think it is hard mounted as I recall. The first weld that broke was the flange on the H pipe to the right exhaust. It broke while jacked up. The second break was to the R/muffler flange when my wife was driving down the road. She got it to a Midas and they were able to weld it but said after looking at it that it would break again. Third brake was to L/muffler flange as she accelerated hard to pass. I have heard that the early C5's had a problem w/the welds, That is why I'm looking for an X pipe and used (but newer) set of mufflers that I will have reinforced. Anyone have a good used X pipe for sale?
Klammer
Originally Posted by Bluefire
Just a thought...
Old Jul 29, 2008 | 11:13 AM
tabbruzz's Avatar
tabbruzz
Do a search on X-pipe. This has been discussed many many times and you should be able to find all the info you need to make a decision...
Old Jul 30, 2008 | 01:45 PM
Glen Green 65's Avatar
Glen Green 65
I have a Corsa X pipe nd cat back. I noticed a positive difference. Intall is srtright forward and easy.
Old Jul 30, 2008 | 02:32 PM
1slowFRC's Avatar
1slowFRC
I just purchased a CORSA x-pipe and TPiS Headers, I'll let you know how the install goes, but USED the X-Pipe looks in really good shape and would recommend them for your situation. Do you still have the stock exhaust?
Old Jul 30, 2008 | 02:56 PM
Last C5's Avatar
Last C5
The Corsa X pipe is a good product, but it's not a true X pipe. Bassani and Magnaflow are true X Pipes.
Old Jul 30, 2008 | 03:22 PM
1slowFRC's Avatar
1slowFRC
Really...whats the difference?
Old Jul 30, 2008 | 03:39 PM
Bluefire's Avatar
Bluefire
Old Jul 30, 2008 | 04:16 PM
klammer76's Avatar
klammer76
Yes, I will be using stock exhaust or Zo6 exhaust if I find one.
Klammer
Old Jul 30, 2008 | 04:22 PM
1slowFRC's Avatar
1slowFRC
You should have no issues with fitment either way...I would suggest having them welded up to the cats and using clamps for the rest. This will be the route I am going and will let you know after the process. My install is set for th 15th of August and I can't wait!!!
Old Jul 30, 2008 | 05:31 PM
Last C5's Avatar
Last C5
The Corsa pipe is two pipes mated together with the overlap removed. The Corsa will stop the popping and gurgling and it's a whole bunch better than your stock setup, but doesn't provide the same scavaging effect as a true X pipe. Take a look at some pictures of the Bassani, Magnaflow, or Dynamax X pipe and compare it to the Corsa. Whether the scavanging effect is that important or not is up for discussion, but NASCAR runs the true X pipe version so they must think it helps.
Old Jul 30, 2008 | 07:37 PM
The Wrench's Avatar
The Wrench
One band-aid way to relieve stress on the flanged junction just ahead of the rear axle is to run two gaskets rather than one, and don't over-tighten the bolts. This allows a bit of give when the systems twists and flexes under engine and chassis load.
The gaskets won't leak enough to notice, if at all. Of course, be sure everything is bolted up with no stress, and spring/rubber mounted as intended.
DG
Old Jul 30, 2008 | 07:52 PM
Stevedore's Avatar
Stevedore
Active Streak: 90 Days
St. Jude Donor '03-'05-'06-'07-'08,'11 thru '17, '21
One of the flange welds broke on my original pipe several years ago. I installed a Corsa x-pipe (I have a Corsa exhaust) & have had no problems yet. It did smooth out the sound noticeably.
I used the free Autozone loaner chain cutter to cut the pipes forward of the original H section. Measure twice, cut once!
Old Jul 31, 2008 | 10:13 AM
Rob Razor's Avatar
Rob Razor
Installed the Bassani X-Pipe with Corsa Indy mufflers in 2004, sounds great and no issues.
To X pipe Info / opinions
