C6 Z06 Wheels on a C5 Trouble
Old Jul 30, 2008 | 11:36 AM
nwdanner's Avatar
nwdanner
Originally Posted by catch06
You're right Doug, thank you. I will start looking for the L5 fenders, or sell the tire wheel combo...don't think raising the car back up will be enough...
Keep the wheels! Do the L5 fenders with the modified C6Z06 splash guards -- you'll love the end result. I'm sure you've seen the pics posted on this forum showing this setup. If I had the $$$ (frick'n stock market) this is the route I'd take. It looks killer IMO!
Old Jul 30, 2008 | 11:41 AM
dougbfresh's Avatar
dougbfresh
The flares won't help. They'll just extend the LOOK of the fender out, not the fender itself.
Old Jul 30, 2008 | 11:49 AM
nwdanner's Avatar
nwdanner
So you're saying the L5 flared fenders are "non-functional"? That's certainly not what I've seen/heard in other posts on this forum...
Old Jul 30, 2008 | 12:31 PM
catch06's Avatar
catch06
Fact is, I haven't seen/heard any problems with this setup except mine...which is why I thought it might be something else wrong...
Old Jul 30, 2008 | 12:59 PM
catch06's Avatar
catch06
dbf might be right, if you look at the pics of the L5 fenders on the eastcoastvette site, I don't know why it wouldn't catch...look how low the clearance is...could they hit any bump? I have at least that much clearance...maybe if I post this in general someone who has them could pipe up....
Last edited by catch06; Jul 30, 2008 at 01:00 PM. Reason: Used Dougbfresh's wrong initials
Old Jul 30, 2008 | 01:47 PM
BlackZ06's Avatar
BlackZ06
Definitely a tough lesson...the wheel shop is a very well known and used wheel shop here in the KC area...handle a lot of wheel jobs...but no, they don't specialize in vettes...the shop suggested the place to get the car lowered...it wasn't lowered when I put the wheels on...its obvious now that the wheels/tires are probably too big without the flares...even if I raise the car back up, I would be afraid it could travel that far and crack again...
Yup, even if you do raise it again you will damage the panel again some day. You either need to put a more appropriate wheel/tire size on the car, or flare the fenders. Sounds like you need a mini-tub also if your wheelwell liners are being damaged.
Look at a picture of a Corvette taking a corner at high speed, or look at how much the tail "squats" under hard acceleration .... you can probably get the tires rubbing the body panel in either of those two cases, let alone adding a bump to it.
You may not be able to move the car much ... but what's your body weight ... 200 lbs ???? ...... How much weight gets transferred to the rear suspension under hard acceleration ???? .... probably 1,000 pounds .... your weight is puny compared to the weight shifts the suspension has to cope with .... and add to that the loads that occur when a wheel drops into a pothole and the tire/wheel is "launched" up into the car when it hits the other side of the hole ..... it isn't that hard to hit the bump stops (that's why they are there).
Old Jul 30, 2008 | 02:08 PM
catch06's Avatar
catch06
Excellent, well unless someone wants to buy the wheels, then its flared fenders for me! Thanks all for the help, I appreciate it...
Old Jul 30, 2008 | 02:31 PM
gorillavet's Avatar
gorillavet
L5 fenders will work. I run 345's on a c5.
Old Jul 30, 2008 | 05:48 PM
jdmvette's Avatar
jdmvette
Night Owl for life
yeah as others have said, they're sticking out too far. the suspension must have compressed too far and caused the fender to hit the top of the tire.
as far as the inside wheelwell rubbing out, you need to add a spacer if you want to run this size for clearance.
here's how yours looks vs mine with the same wheels, 345 tires, 5/8" spacers and L5 flares.
vs.
wrong.
Old Jul 31, 2008 | 12:40 AM
catch06's Avatar
catch06
[QUOTE=jdmvette;1566519082]yeah as others have said, they're sticking out too far. the suspension must have compressed too far and caused the fender to hit the top of the tire.
vs.
Sold! Where is the best place to get them?
Old Jul 31, 2008 | 01:29 AM
jdmvette's Avatar
jdmvette
Night Owl for life
here.
Old Aug 1, 2008 | 10:16 AM
dougbfresh's Avatar
dougbfresh
Assuming he gets a wider fender and wheel well to go with it, unless the tire fits the well, and the well is TALLER, he will still have the same problems.
Old Aug 1, 2008 | 11:15 AM
  #33
jdmvette's Avatar
jdmvette
Night Owl for life
so you think that people who actually have the L5 flares are having those "problems" you mention?
Old Aug 1, 2008 | 12:09 PM
  #34
gmethod's Avatar
gmethod
JDM is dead on the money...fender flares and the spacer will fix your problem.
Old Aug 1, 2008 | 01:20 PM
  #35
Drewstein's Avatar
Drewstein
I run the exact same rims with 335s and have no problem with clearance and I lowered the vette on aftermarket bolts as well. L5s will solve this issue easily.
Second, you don't have to get the doors painted to match the fenders. If the shop is any good they can put it dead on to match the doors. Just make sure they put the orange peel in it as well as the proper color.
