Pinning a keyed Pulley??
Old Jul 29, 2008 | 08:06 PM
bcarp's Avatar
bcarp
A & A is in my future so I am doing it while it is apart
Old Jul 29, 2008 | 09:16 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Anyone got a how to for pinning the crank on an after-market keyed balancer and stock crank ?
Also where do you buy some extra pins ??
Old Jul 29, 2008 | 09:19 PM
bcarp's Avatar
bcarp
If not then maybe I am about to do one
Old Jul 29, 2008 | 10:19 PM
MikeV's Avatar
MikeV
Pins are usually sized by a number. Look at mcmaster carr for sizing.
Mike V
Old Jul 29, 2008 | 10:46 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Originally Posted by lucky131969
So you put a round peg in a square hole...purposely....
It wasn't a square hole when I was done with it! I used a 1/4" carbide bit on my angled die grinder, set the rpm low and radiused the square to round. The keyways are broached 3/16" and the pins are 1/4" I was careful to watch the sides round out then the bit touched the bottom of the keyway. I knew I only had to go into the base of the groove 1/16" and by the time I did, the key groove was round. For the OP, if you're unsure about doing this, just pin it on the other side 180° out and don't listen to the noise about balance. You're not talking about some significant weight hanging off a 12" radius spinning at 10krpm, you're talking about removing a few grams of metal and replacing it with a few grams of metal like someone else mentioned before.
Old Jul 29, 2008 | 10:49 PM
BLOWNBLUEZ06
You won't regret it! Andy's a great guy with a fantastic product! Read my signature and you'll see that I'm finishing building a reasonably high hp car with his Ysi kit.
Old Jul 30, 2008 | 05:40 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Mike V
Thanks.
Old Jul 31, 2008 | 12:11 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
We pin vertically with the ATI pinning jig for non-keyway cranks
The same kit that Tom posted (Y2kvert4me)
Old Jul 31, 2008 | 12:59 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Thanks.
