Changing valve spring directions
Old Jul 29, 2008 | 10:28 PM
kevint21's Avatar
kevint21
Default Changing valve spring directions
Does anyone have directions and tools needed to change valve springs? It looks like some type of air compressor/attachment is needed to keep the valve up and a tool is needed to compress the springs. Thanks in advance
Old Jul 30, 2008 | 11:49 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Thunder racing sells the tool and you use a compressor and compression checker with the schrader valve removed and a compressor fitting at the other end. Instructions at LS1howto.com, but their site seems to be down today. look under cam swap instructions.
Old Jul 30, 2008 | 12:10 PM
99C5JA1's Avatar
99C5JA1
As discussed in your other thread you can either use an air compressor attachment that screws into the plug hole to keep the valves up or you can position the piston to where it is at TDC to keep the valve from dropping into the cylinder. With either method you will need a valve spring compressor to remove and install the springs.
Old Jul 30, 2008 | 01:10 PM
BLOWNBLUEZ06
Standard valvespring bar type compressors don't work very well on these cars. That's why I recommended the Thunder racing version. It will make your life alot easier.
Old Jul 30, 2008 | 01:23 PM
lucky131969's Avatar
lucky131969
For the same money, the crane cams LS1 valve spring compressor does both valves at a time, as opposed to the thunder racing which only does one valve at a time. I have the crane cams valve spring compressor, and it works perfect. It makes changing springs a short job, especially when using the TDC method, because you can do two cylinders at one time.
Old Jul 30, 2008 | 03:20 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Crane tool all the way!!
Old Jul 30, 2008 | 03:49 PM
BLOWNBLUEZ06
Nice tip! Thanks!
To Changing valve spring directions
