Rear Lowering Kit Question
Old Dec 30, 2001 | 10:51 AM
GR8-LIFE's Avatar
GR8-LIFE
Default Rear Lowering Kit Question
I'm lowering the front as far as the fac bolts will allow but I'm going to be lowering the rear just a tad bit more. I know they sell these Rear Lowering Kits. Where can get them? How much are they? Could I purchase generic bolts from the Local Hardware store instead and If I can, what exactly should I be looking for? Or are there any simplicity advantages to just buying the kit?
Old Dec 30, 2001 | 11:57 AM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: Rear Lowering Kit Question (Ha-Ha)
If you want to waste your money, buy the kits. If you want to get the same results for less than ten dollars, buy them from a local bolt supply store.
7 inch long 9/16 bolts, flat washers, locking nuts. 9/16 bolts are real hard to find in that length, you will find that a very large % of people here are using the 1/2 bolts with absolutely no problems. :cheers:
[Modified by racer44, 8:58 AM 12/30/2001]
Old Dec 30, 2001 | 12:10 PM
Chuck Broten's Avatar
Chuck Broten
Default Re: Rear Lowering Kit Question (racer44)
My situation is a little different here in Germany so I went and bought the kit with the bushings. This way, I could save the factory bushing if I wanted to.
I will guarantee you one thing, lowering the rear can have a real significant effect on the ride quality. Like you, I have the Z51 and the bouncing, like I had a load of bricks in the back, was very bothersome. I went with the Bilsteins from LAPD and that fixed the problem. One thing I have learned is that you can count on Shawn and LAPD.
Once your car is lowered it is truely amazing how much better it will look. Just an inch and a half makes a difference. Awhile back, I drove my son-in-laws Ruf 911 to the Autocross with him following in the C5. With the lowering and the Breathless non-popup headlights the car looked absolutely menacing in the rearview mirror. The c5 was in back because.... I wanted it that way. :)
By the way, I loved driving the Ruf...... 170K car.... but liked the many refined qualities of the C5 better.
:cheers: :cheers: :cheers:
I keep posting and cheering with the beer drinkers.... maybe I have a problem?
:U
MilYellow02's Avatar
MilYellow02
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
If you are only lowering the front bolts all the way down, there is no need to buy longer bolts for the rear. The front won't even drop but about 1/4". If this is all you need, which is fine, just turn the stock back bolts leaving about 2 threads on the back bolts. :yesnod:
Old Dec 30, 2001 | 12:11 PM
NastyC5's Avatar
NastyC5
I spent the $44 and bought the RKsport lowering bolts. They also come with urethane bushings ;)
Old Dec 30, 2001 | 12:25 PM
Racer's Avatar
St. Jude Donor '11
I guess I should of said, if you want to save money, not waste money as I think the urethane bushings would be OK to have. :cheers: Also, if you don't think the front will go down enough for your tastes, then you can follow this link for slamming it into the weeds! :D I did and very, very happy with it!!!!
http://www.corvetteforum.cc/techtips...D=90&TopicID=1
Old Dec 30, 2001 | 01:31 PM
Patman36's Avatar
Patman36
Will this technique work with non-Z06's? Just wondering... I would love to lower and will eventually get some Bilstein's...
Patrick :seeya
[Modified by Patman36, 11:31 AM 12/30/2001]
Old Dec 30, 2001 | 01:52 PM
MilYellow02
Default Re: Rear Lowering Kit Question (Patman36)
I cut two bushings in front, longer bolts in back and went from
front 27.75" to 26.70
rear 28.50" to 27.11
Old Dec 30, 2001 | 03:11 PM
Racer's Avatar
St. Jude Donor '11
It works with all Z-51 suspensions.
:seeya
[Modified by racer44, 12:11 PM 12/30/2001]
To Rear Lowering Kit Question
