Easy question....e-brake
Old Jul 30, 2008 | 07:20 PM
nightman06's Avatar
nightman06
Default Easy question....e-brake
Just wondering how to tighten the e-brake cable. Right now it is just tight enough to keep it from rolling backwards. I can rip it all the way and it doesn't even drag rolling forward.
Old Jul 30, 2008 | 08:08 PM
Nick1's Avatar
Nick1
You will see lots on this, check the search section under emergency brake. If your handy, you will have reasonable success improving the overall effectiveness. I messed with mine quite a bit, even though it was no so bad.
Still it dosn't lock up in a manner that I would like.
Old Jul 30, 2008 | 10:17 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I went back to old-school methods and adjusted mine that never worked. Once done, it worked perfectly. Its a drum brake setup. Take the rotor/drum off, adjust the shoes outward with the regular adjuster a bit and try putting the rotor/drum back on. Keep doing this until you can just barely get it on. Do both sides the same. If it had a window on the backside of the brake assembly, then you could adjust it the way of the old days without having to remove the rotor/drum.
Old Jul 31, 2008 | 12:00 AM
rws.1's Avatar
rws.1
check out this fellow forum members web site...
check out both #3 and #4
http://www.ronjpics.com/Corvettestuff.htm
Old Jul 31, 2008 | 12:04 AM
nightman06's Avatar
nightman06
Excellent stuff there. I actually have the wheels and such off for a shock change out so I will just continue with the adjustment of the shoes. Thanks a lot!!
To Easy question....e-brake
