ARE REV-KIT???
Old Dec 30, 2001 | 01:00 PM
Closer_2001's Avatar
Closer_2001
Default ARE REV-KIT???
I'm trying to absorb as much info as I can about Cams, so I started pulling out the back issues of some mags.
GMHTP ran a story on their ARE Heads/Cam Silver 98 Z28 that included the use of the "ARE REV-KIT" that allowed safe operation up to 6700 RPM. Basically, the kit applies spring pressure to the lifter by squeezing a sprung pair of billet plates into the lifter valley. This prevents the lifter from the leaving the cam lobe and floating the valves. Does anyone know anything about this?
Old Dec 30, 2001 | 01:05 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: ARE REV-KIT??? (Closer_2001)
Most applications call for this mod with high lift cam and solid lifters.
Old Dec 30, 2001 | 02:43 PM
intel55's Avatar
intel55
Yes, I have used one. It worked fine. Helps keep the lifters in their bore to a greater extent on hi revs and roller cam. Less chance of a float when your spinning hi and the vavletrain builds momentum to go the other way.
Old Dec 30, 2001 | 07:56 PM
Closer_2001
Default Re: ARE REV-KIT??? (intel55)
So are many people using these, or is it really unnecessary with the proper valve-springs in place.
Old Dec 31, 2001 | 12:57 AM
ZAP's Avatar
ZAP
It is a great engine saver if you run high revs. :cheers:
Old Dec 31, 2001 | 03:11 PM
C5 Tweaker's Avatar
C5 Tweaker
I am running a 6800 RPM fuel cutoff on my 2001 with dual valve springs (MTI), hardened rods, stock rockers, 'big' valves, and a 222 .566 cam. No issues.
Sure is nice having the added range up in the power band.
To ARE REV-KIT???
