tq specs
Old Jul 31, 2008 | 08:51 PM
Kurtomac's Avatar
Kurtomac
Default tq specs
hopefully needing these tomorrow....tq specs on everything for the HCI swap on a 02z06...ls1howto site is down and i planned on using that
need:
water pump
crank bolt
power steering bolts and lines into the vavle housing of the rack specs
coil packs
rockers
lifter covers thingers whatever theyre called
heads w/arp head bolts and sequence
intake
coolant tubes
temp sensor
cam bolts
retainer bolts
timing cover bolts
and anything else you guys can think of off the top of your heads
