Turn signals intermittantly dont work
Old Aug 1, 2008 | 06:38 AM
1badf350's Avatar
1badf350
Default Turn signals intermittantly dont work
Guys a couple times a day my turn signals just wont work, no green flashing dash arrows, no anything.
But the hazard lights will work and I'll get both green arrows flashing for hazards.
Also, during a period of non working signals, if I hit the brakes with the turn signal engaged the brake light on that side will not come on.
Example, right turn signal on + step on brake = no right brake light
Old Aug 1, 2008 | 07:07 AM
RSchleder's Avatar
RSchleder
Default Bi-pass cable
Had the same issue a year ago. I bought the Bi-pass cable from Richard @ Corvette Enhancements and the issue is totally gone. The cable costs $60 and takes 20 min's to install. Give Richard a call@1-800-946-4929 and explain your problem. He'll give you good advise!
Old Aug 1, 2008 | 08:22 AM
Twospeed's Avatar
Twospeed
It sounds like your emergency flasher is going bad. The grounds for that circut all go through the flasher, another GM great design. It is less than $45.00 from the dealership. There are quite a few write ups with pictures to show you how to, on this board. It took me about half an hour to do mine. No problems since. Mine began with the same issues that you and many others describe.
I have no idea what a $60.00 by-pass cable even is or whay it is used for?
Old Aug 1, 2008 | 08:40 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
You can either replace the flasher switch or do the relay mentioned above. The relay bypasses the stock switch and is great if you'd ever add led tailights as it also eliminates the hyperflash common with the led tailights
Old Aug 1, 2008 | 09:57 AM
95BlueBomber's Avatar
95BlueBomber
Just changed one out on my brothers 2000
Old Aug 1, 2008 | 01:36 PM
1badf350's Avatar
1badf350
Thanks guys. ANybody have a part number for the flasher switch?
Old Aug 1, 2008 | 02:59 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Your hazard switch has gone bad Happened to me years ago. I had it replaced under warranty and I believe they had to pull the dash, but I know there's a shortcut that's been posted on here somewhere.
Old Aug 1, 2008 | 04:13 PM
c5streak's Avatar
c5streak
Part # 10359036
Here's a DIY if you tackle it yourself.
http://myweb.cableone.net/kd5fx/HSwitch/HSwitch.htm
Old Aug 1, 2008 | 04:15 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
thanks - last week my 01 the flasher stopped working. I was like WTF and then I hit the hazards and they worked. I tried the blinkers and then they worked fine
It has happen twice since and I was getting ready to look into the problem and presto this post is here.
Old Aug 1, 2008 | 04:16 PM
Wicked Weasel
Originally Posted by c5streak
Part # 10359036
thanks
Old Aug 1, 2008 | 05:27 PM
lloyd's Avatar
lloyd
Default turn signals
Ever now and then just push your 4 way flasher switch several times. Seems that it needs to be used to keep the turn signals working.
Lloyd Harvey
Corvette Care, Inc
Columbus, OH
614-471-3331
Old Aug 1, 2008 | 06:08 PM
Cobra4B's Avatar
Cobra4B
^ Yes, that means the hazard switch is failing.
Old Aug 1, 2008 | 06:15 PM
patton's Avatar
patton
St. Jude Donor '09
cycle the haz button a few times and the sigs will start working again
Old Aug 1, 2008 | 06:26 PM
Cobra4B's Avatar
Cobra4B
^ Correct... but again it won't fix the root of the issue.
To Turn signals intermittantly dont work
