Oil filter torque????????
Old Dec 30, 2001 | 04:40 PM
Fox's Avatar
Fox
Default Oil filter torque????????
I'm under the car now just getting ready to put the new filter on, and I realized that I don't have the torque specification for the oil filter written down. Seems that it was posted here before, but I have forgotten it. Did a search, no results, can't find it in the shop manual..........anyone know it?
Old Dec 30, 2001 | 05:10 PM
KSB's Avatar
KSB
Default Re: Oil filter torque???????? (Fox)
Until you get # hand tight should be fine. :chevy
Old Dec 30, 2001 | 05:20 PM
chadwick's Avatar
chadwick
30 Nm, 22 lb-ft, page 6-9 of the service manual
:cheers:
Old Dec 30, 2001 | 05:25 PM
Fox's Avatar
Fox
Default Re: Oil filter torque???????? (chadwick)
Thanks Chadwick, I'll make a note of it.
Old Dec 30, 2001 | 07:04 PM
RAGGDOLL's Avatar
RAGGDOLL
Toronto Events Coordinator
I torqued mine to the recommended 22 lb-ft and man did that ever seem way too tight, much more pressure than I would have applied if doing it by hand.
Anyone else have this same feeling?
Oh well, thats the spec and thats what I tightened it to!
Old Dec 30, 2001 | 07:14 PM
jschindler's Avatar
jschindler
Default Re: Oil filter torque???????? (mjager)
Just curious. How are you guys torqueing these puppies? I know a few have "nuts" on them, but not many.
Old Dec 30, 2001 | 07:47 PM
MDT's Avatar
MDT
Never torqued a filter in my life. I've always tightened until the gasket makes contact plus another 3/4 turn.
Good luck.
Mark
Old Dec 30, 2001 | 08:03 PM
RAGGDOLL's Avatar
RAGGDOLL
Default Re: Oil filter torque???????? (jschindler)
You need a special oil filter "cap" tool, it's round and plastic and slides on the end of the filter. It has a gripping type design on the internal part that slides on the filter and a built in 3/8" square fitting for a standard 3/8" extension. They only cost about 5 bucks. I started using them for my ATV as it's the only way I can get the filter off due to space limitations.
I've always done my oil filters by hand as MDT says, but since I got a new torque wrench, I thought I may as well use it for everything I had torque spec's for. Like I mentioned earlier, that 22 lb-ft torque sure seemed way too tight from what I'd normally tightened it to by hand "feel"
Old Dec 30, 2001 | 08:04 PM
ASTROS's Avatar
ASTROS
Default Re: Oil filter torque???????? (MDT)
put it on too tight and you will have to beat it off when you get ready to remove it
Old Dec 30, 2001 | 08:36 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Should be hand tight, use two hands!
Old Dec 31, 2001 | 05:33 PM
Fox's Avatar
Fox
Default Re: Oil filter torque???????? (wallstAL)
Just a quick update, 22ft/lbs. was just a little less than one full turn after the gasket contacted, so the old rule of 3/4-1 full turn is pretty close. Hand tight is also in the ballpark, it's probably not that critical but I figure I have the torque wrench so why not. Thanks to all who replied. :)
Old Dec 31, 2001 | 09:39 PM
Sunset Vette's Avatar
Sunset Vette
Remember, there is no actual oil "pressure" where the filter is, just has to be tight enough to not leak or vibrate off. Spin it until it's tight, then a 3/4 turn more for insurance is good enough.
Don't forget to moisten the gasket with oil before you do... makes it much easier to get off the next time. ;)
Dave
Old Dec 31, 2001 | 10:46 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Getting one off that is put on too tight is not much fun. :eek:
Old Jan 1, 2002 | 08:21 AM
Tom/99's Avatar
Tom/99
I have always tightened my filters, 3/4 to 1 full turn, after the gasket makes contact.
Old Jan 1, 2002 | 11:32 AM
carpe dm's Avatar
carpe dm
Contact plus 3/4 turn seems to be the rule. That is what I have always used, and even then I have had trouble getting them off once in awhile. :) BTW, I recently talked to a GM engine engineer who told me he thinks the filter should be changed evry 3 or 4K regardless of your selected oil change interval. :chevy :)
Old Jan 1, 2002 | 11:48 AM
white93's Avatar
white93
Default Re: Oil filter torque???????? (carpe dm)
I've always tightened pretty snug by hand, then backed off just a bit so removing it isn't a problem. That has worked for me; no leaks and no problems removing the filter the next time. Probably winds up at about the contact +3/4 turn point.
Old Jan 1, 2002 | 08:08 PM
JohnS's Avatar
JohnS
I tried 22 ft lbs also and chickened out after a full turn from finger tight. I thought that spec seemed to make it too tight also - I just went 3/4 turn after finger tight (that makes it pretty tight but not too difficult to remove - no problems yet).
JohnS
To Oil filter torque????????
Old Jan 4, 2002 | 07:21 AM
LIGHTNING's Avatar
LIGHTNING
Default Re: Oil filter torque???????? (JohnS)
used to torque 3/4 turn after gasket contact, until one ultragold filter began leaking, possibly due to over tightning. now i just hand-tighten. no more leaks!
Old Jan 4, 2002 | 09:48 AM
C5Longhorn's Avatar
C5Longhorn
Default Re: Oil filter torque???????? (LIGHTNING)
I'm also an individual that always used my hands to torque the filter. So far, so good.
Old Jan 4, 2002 | 10:32 AM
99HT's Avatar
99HT
If you were unlucky like me and numerous others, you would need to crank down HARD on your oil filter to get a good seal. My filter O ring mating surface on the block has deep scratches in it. It seems the guy grinding off the casting flash at the block manufacturer was careless. The final decking by the NC machine did not remove the scratches. I have to use a 2 foot wrench and a oil filter socket to tighten and loosen my filter. Dealer says he would have to replace the block under warranty to fix the problem. My engine runs sweet and does not use any oil. I said no thanks.
