High temp hose needed - Ideas?
Old Aug 2, 2008 | 01:05 PM
94legaleagle's Avatar
94legaleagle
Default High temp hose needed - Ideas?
This is more of a tech question than a WTB question so that's why it's in the tech section
2001 Vette w/ Dynatech headers - on the top of the pass side header is the pipe/flange for the air tubing - when I installed the headers, the factory air pipe flange and the flange on the header air pipe did not want to line up perfect (only flaw I found w/ this set of headers) - so, being creative, I "removed" (ie: cut out w/ a hack saw) a 2" piece of the 3/8" or 1/2" inch factor air pipe - NOT on the header, but on the factory air pipe
Then, I inserted a piece of 3/8 or 1/2 inch (can't remember the inside diameter, and doesn't matter, the principle is the same) over the end of the factory air pipes thereby rejoining the pipes together - so I had factory air pipe running from the back of the firewall and down the pass side of the engine, then the 3/8 or 1/2 inch radiator hose, then the factory air pipe w/ the flange on it - this gave me some "flex" in the factory air pipe and I was able to easily get the flange on the factory air pipe to meet up with the air pipe flange on the pass side header
Well, this worked for about 2 years (I'd kind of forgotten about it), and you've guessed by now that the 3/8 or 1/2 inch radiator hose was NOT able to withstand the exhaust temp on the line - so the hose finally turned to a crumbly charcoal (it didn't burn, luckily)
I need to replace the hose, and I could get by w/ the same type radiator hose for a year or so, but the problem will repeat itself - SO, I'm looking for some type of hose that can withstand HIGH temps (read exhaust temps) yet is somewhat flexible like the radiator hose and has a 3/8 or 1/2 inch INSIDE diameter that can be slipped over the pass side exhaust tube and fit SNUG - ANY IDEAS of SOURCES or KIND of hose I'm looking for? if so, please post
Also, I was in the middle of my travels when the "radiator hose/air pipe" that I installed vaporized and became charcoal - I had to travel about 350 miles with the air pipe on the pass side header open - IE: once the hose disintegrated, there was approximately 3 inches of the factory Dynatech air tube coming off the pass header, then the two flanges bolted together, and about another 3 - 4 inches of factory air pipe - but then the air pipe was open so I had an exhaust leak, so to speak - Did I cause any damage to my engine as a result of this condition, and if so what kind of damage and what should I look for?
thanks.
Old Aug 2, 2008 | 01:57 PM
jedblanks's Avatar
jedblanks
I don't think you caused any damage to your engine, unless you see visible damage from hot the exahust in the engine compartment.
As far as hose, I'd find a buddy that was a welder and see if he/she(lol) can put a stainless or at least galvanized piece in there with a wire welder.
I don't think any rubber hose will hold up, not sure what else you can use.
Old Aug 2, 2008 | 01:58 PM
jedblanks's Avatar
jedblanks
On the other hand you could just buy block off plates, and have the air tube turned off by a tuner. You can remove all the piping later if you want.
Old Aug 2, 2008 | 02:07 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
In the past, I had to replace a cat converter on an old "beater" that I was driving for a winter/second car. I bought a "universal" converter, and the auto parts store sold me some "high temp" rubber hose to hook up the air inection line. I thought the heat of the cat would toast it in no time, but it held up for about 2-3 years, and at that point I sold the car, so I don't know exactly how long it lasted.
To High temp hose needed - Ideas?
