03" Draining battery ??
Old Aug 2, 2008 | 02:40 PM
mavrick331's Avatar
mavrick331
Default 03" Draining battery ??
I have an 03’ six speed with 16k on it, Wednesday morning it would not start, everything was dead, no lights, horn no nothing. After a few minutes of charging the battery with the help of my 73” I got it started. I drove the car out of town, round trip was 200 miles with several stops along the way and the car was fine reading 14.1 volts on the display. I just assumed I left something on. Friday morning I hopped in, same thing, deader than a doornail.
Last night I pulled the battery and ran it in my truck for about an hour, this morning the truck started fine, so this morning I took the battery and had it checked anyway hoping it was bad, but it tested good. When I connect the battery up I get a small arc or bite. One by one I pulled the fuses and relays next to the battery to see it the arc stopped, no difference.
The only electrical add on was an IPOD to car that I installed 6 months ago. Anyone have any ideas? I am at my skill levels end; next stop would be to take to GM with keys in one hand and Vaseline in the other.
Thanks,
Old Aug 3, 2008 | 03:44 AM
NavyDoc2007's Avatar
NavyDoc2007
Here's a thread explaining how to check for current draw. http://forums.corvetteforum.com/show...rent+draw+test
I agree with checking the power seat switches. I had this problem off and on for about a year and found the problem by dumb luck: I just happened to touch the top of my driver's side sun visor and found the plastic door that covers the mirror was warm...and the car had not been driven in a day. It turned out that the cover wasn't pushing the button down far enough to turn the mirror lights off. All I did was tape a quarter on the back side of the cover so it would push the switch down far enough to keep the lights off. I didn't feel like putting the effort into taking the visor apart to fix it since I don't use the mirror anyway. All it cost me was 25 cents....
Old Aug 3, 2008 | 07:43 AM
dndrsn's Avatar
dndrsn
http://forums.corvetteforum.com/show....php?t=2063102
Old Aug 3, 2008 | 09:39 AM
dndrsn's Avatar
dndrsn
Originally Posted by 8VETTE7
Great find dndrsn!!!
I don't read the General board often enough and this info about the Ipod setup is very interesting. I don't have one in my car but had been giving it some thought. The way the battery in my Ipod is always run down, I'd probably be draining the Vette battery just to keep the poor battery in the Ipod charged.
In my case it didn't have anything to do with charging the iPod. The Peripheral would still draw current even with the iPod unattached. I never left my iPod in the car. I did the current draw test and found the ipod2car Peripheral to be the culprit. Since it has been disconnected I have had no problems with battery drain.
If I had been driving my car daily, I probably would not have noticed. The original poster said his battery would drain overnight which would make me think that there may be something besides the ipod2car that is adding to his problem.
My car would have to sit for several days to drain low enough to not start the engine.
Old Aug 5, 2008 | 09:37 PM
mavrick331's Avatar
mavrick331
I used a VOM set to DCA on 10a between the neg. battery post and the neg cable, I read about 6.1 amps. Pulling fuses 1 by 1 I found in the foot well fuse box at # 25, marked BCM1 & IPC, when pulled it drops down to 1.6 amps, a few minutes later with everything closed it goes down to about .02 amps. I decided to connect the battery back with # 25 pulled to see if it drained overnight, I still see a considerable “arc” when connecting back at the battery. I also tried to start the car, nothing, all interior components are out as well, horn, lights, seat, I left the battery disconnected.
What is # 25? Does it control the entire fuse box in the foot well? Should I leave that fuse in and continue pulling fuses?. I worked from the bottom up, so I had about 15 more to go…..
Thanks,
Rick
Old Aug 5, 2008 | 11:57 PM
bestvettever's Avatar
bestvettever
Thanks,
Rick
Hi, do you have any codes set?
Fuse #25 powers the BCM and the Instrument Panel Cluster.
A small arc is typical when connecting the battery back up.
The draw without 25 in is normal. Something that the Bcm 1 is controlling is the culprit.
You need to reinstall fuse 25, and do the rest of them in all the fuse blocks, to find the culprit.
Some of the usual suspects have been the Vanity mirrors not shutting off, check in a dark garage or at night and look for a light on either at the vanity mirrors, the rear view mirror inside lights, the glove box light, or trunk and underhood light. Also the seat motors including the lumbar motors can go on intermittently all night. The door locks if you have the passive fobs can be activating if the fob is close enough.
Good Luck
Old Aug 7, 2008 | 10:02 PM
mavrick331's Avatar
mavrick331
I read several other threads on this forum which allowed me to isolate the draw to the fuse panel in the passenger side foot well, oddly enough when I isolated it from the under hood panel, the headlights popped up but were not illuminated. After crosschecking that I had the correct panel, I connected back to factory, and then the headlights dropped down…..
I then pulled all the relays in the foot well, no change with a steady 6 3 amps draw, then I pulled all fuses, zero draw, reinstalled # 25 and had a steady 1.8 amps draw.
Inserted each fuse one by one, several fuses added .1 to .6 amps of draw. I disregarded these and found # 5 pulling 1.4 amps and # 29 pulling about the same. I waited with everything closed with #’s 5 & 29 pulled for the car to go to sleep, but never saw it drop below 1.8 amps. I also tried 5 & 29 individually. Part of my problem seems to be that the car won’t go to sleep
I have a decent skill level in troubleshooting current draw, mostly in a AC to DC network, but this is getting tricky, the Vaseline is looking pretty good about now…. Unless the experts here can read between what I have troubleshot..…
Thanks,
Rick
PS. the yellow 03' in my sig. is gone, this car is a spiral grey 03' 6-speed vert. Maybe this changes something.....LOL
Old Aug 7, 2008 | 11:31 PM
bestvettever
Default Current Draw
Hi, did you say you had an ipod adapter in your car? Fuse #5 is the radio/Cd Player. And I've heard that ipod adapters can drain a battery even though the ipod is not connected to it. And if you are going to ask the logical question, how come the adapter didn't drain the battery 6 months ago when you installed it, the possible answer is that it has been draining it for 6 months and the battery has finally reached the point of weakness that it can't handle that constant drain anymore. One possible suggestion is try a new battery and see if the car starts after overnite or even a few day inactivity. If it does that tells you that the battery even though it showed good was in fact to weak for the vettes draw, and the other suggestion is to disconnect the ipod adapter and see what the draw is and if the car still has the high drain, and if the car will start after a day or two with the old battery. Fuse 29 is the curtesy lamps which would lead me to think that you may have a light that is not going off.
As long as something is drawing current the car will not go to sleep.
Good Luck
Old Aug 7, 2008 | 11:44 PM
bestvettever
Default BCM Description
Hi, the info below may help you isolate the problem. A quick guess by me would be the Radio/cd circuit, or the curtesy lamps circuit, and a slim possibility that the ig switch is bad.
SEE Below
Body Control System Description and Operation
This vehicle is equipped with a Body Control Module (BCM) capable of performing multiple body control functions. The BCM, which is the power mode master, is responsible for sending the power mode messages on the serial data line to other systems.
Serial Data Power Mode
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle the PMM is the Body Control Module (BCM). The PMM receives two signals/circuits from the ignition switch. These are the Ignition 1 and Ignition 2 ignition switch signals/circuits.
To determine the correct power mode the PMM uses:
The state of these signals/circuits, either switch closed (B+ = 1) or switch open (B+ = 0)
The sequence of switch closures received by the PMM
The status of the engine run flag
The chart below indicates the modes detected and transmitted by the PMM:
Correct Ignition Switch Inputs Power Mode Selected/Expected
Engine Run Flag Serial Data
Sampled Ignition Signal State
Power Mode State
Key-In Sense
Ignition 1
Ignition 2
OFF
0
0
0
OFF-AWAKE
NA
RAP
0
0
1-0
RAP
NA
UNLOCK
0
0
0-1
UNLOCK
NA
ACCESSORY
0
0
1
ACCESSORY
NA
RUN
1
1
1
RUN
NA
RUN
0
1
1
RUN
NA
CRANK
0
1
1-0
CRANK
NA
Fail-safe Operation
Since the operation of the vehicle systems depends on the power mode, there is a fail-safe plan in place should the PMM fail to send a power mode message. The fail-safe plan covers those modules using exclusively serial data control of power mode as well as those modules with discrete ignition signal inputs.
Serial Data Messages
The modules that depend exclusively on serial data messages for power modes stay in the state dictated by the last valid PMM message until they can check for the engine run flag status on the serial data circuits. If the PMM fails, the modules monitor the serial data circuit for the engine run flag serial data. If the engine run flag serial data is True, indicating that the engine is running, the modules fail-safe to "RUN". In this state the modules and their subsystems can support all operator requirements. If the engine run flag serial data is False, indicating that the engine is not running, the modules fail-safe to "OFF-AWAKE". In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
On this vehicle the following modules receive Serial Data Messages for power mode status:
Driver Door Module (DDM)
Passenger Door Module (PDM)
Radio
Discrete Ignition Signals
Those modules that have discrete ignition signal inputs also remain in the state dictated by the last valid PMM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, B+, the modules will fail-safe to the "RUN" power mode. If the discrete ignition input is not active, open or 0 voltage, the modules will fail-safe to "OFF-AWAKE". In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
BCM Wake-up/Sleep States
The BCM is able to control or perform all of the BCM functions in the wake-up state. The BCM enters the sleep state when active control or monitoring of system functions has stopped, and the BCM has become idle again. The BCM must detect certain wake-up inputs before entering the wake-up state. The BCM monitors for these inputs during the sleep state, where the BCM is able to detect switch transitions that cause the BCM to wake-up when activated or deactivated. Multiple switch inputs are needed in order to sense both the insertion of the ignition key and the power mode requested. This would allow the BCM to enter a sleep state when the key is IN or OUT of the ignition.
The BCM will enter a wake-up state if any of the following wake-up inputs are detected:
Any activity on the serial data line
Hatch ajar switch
Hatch release switch
Door ajar switch
Key-in-ignition switch
Monitored load relay
Park/fog/headlamps are on
The BCM experiences a battery disconnect and reconnect condition.
The ignition is turned ON.
The BCM will enter a sleep state when all of the following conditions exist:
No activity exists on the serial data line.
The ignition switch is OFF.
No outputs are commanded.
No delay timers are actively counting.
No wake-up inputs are present.
If all these conditions are met the BCM will enter a low power or sleep condition. This condition indicates that the BCM, which is the power mode master of the vehicle, has sent an OFF-ASLEEP message to the other systems on the serial data line.
Power Requirements
The BCM has two main power feeds (high and low current), and two main grounds. The low power feed (battery 1) is used to provide power for the BCMs logic and internal driver operation. The high power feed (battery 2) is used to provide power for systems that draw higher amounts of current (motors, lights, etc.). The BCM will operate properly with a system voltage of 9.0-16.0 volts. If system voltages exceed 16.0 volts the BCM will provide protection by disabling certain functions that may be damaged due to higher than normal system voltages.
Monitored Loads
In order to minimize any battery rundown, the BCM can detect if certain electrical loads have been left ON after the ignition is turned OFF and the driver has left the vehicle. When the BCM detects that the ignition has been cycled to the OFF position, the BCM immediately checks the status of the load monitor input. If the BCM detects that a load is present (grounded input), the BCM turns ON the load monitor relay for 15 minutes. If after 15 minutes the BCM still recognizes that a load is present, the BCM will turn OFF the relay, removing the battery voltage from the loads. The BCM continues to monitor this circuit for a switch transition. The BCM will again turn ON the relay for 15 minutes if a switch transition occurs.
Load Shed Control
The BCM can turn off the rear window defogger and heated outside mirror electrical loads when the vehicle is in a condition where these loads may discharge the battery. The BCM will also remove these loads when engine demands are greater.
Interior Lamp Over Voltage Protection
The BCM disables the interior lamp bulbs when the system voltage is above 18.0 volts in order to extend the bulb life.
Driver in Vehicle Detection
Using the ignition switch/door ajar inputs, the BCM can detect whether or not the driver has left the vehicle. If the ignition is turned to OFF with no door ajar status detected, the BCM assumes that the driver is in the vehicle. As soon as the BCM detects a door ajar, the BCM will assume the driver has left the vehicle. The BCM uses this information to determine the RAP status, then sends the status to the other systems also responsible for RAP functions.
BCM Fail-Soft Condition
If a particular BCM malfunction would result in unacceptable system operation, the BCM takes a fail-soft action in order to minimize the condition. A typical fail-soft action would be the substitution of a fixed input or output value when the BCM is unable to interpret data correctly.
Old Aug 9, 2008 | 04:22 PM
mavrick331's Avatar
mavrick331
As I explained to my co-workers yesterday, one of my pet peeves is when you ask for assistance in a forum, receive it but never respond back with the fix….
I could state here something to the affect that a firefly was trapped between the front headlight and the socket connector, drawing current as it lit up, or something else wild as such…..but, I must man up, only to keep a fellow vette owner from wasting 4 hours of their life as I did.
Hand me the forum’s idiot hat, dumb *** award (can you say *** here?) or other moniker, but the entire issue was the gauge cluster **** was on…..not on the dash, or the console….just plain on.
My troubleshooting led me to 4 fuses pulling various draws from .2 to 1.6 amps totaling 6.3 amps of draw. I could never get the car to sleep because the the draw was coming from the fuse you need inserted to look for the culprit.
I make this admission and add, if you have over .3 amps of draw with only fuse # 25 in the foot well fuse box inserted, go turn the #$%^&%# cluster switch off !!!
That’s it, I’m out, I’m going to curl up with a bottle of crown and ask the gods of horsepower for forgiveness……….
Thanks, Rick
PS. I’m almost out of gas, how do you get the fuel door open ?
Old Aug 9, 2008 | 06:32 PM
bluvette79's Avatar
bluvette79
i have read that there is no way that an alternator will keep the battery fully charged or bring it back from a near death experience. depending on driving habits and system usage it would be a good idea to put a charger on it to make sure it is fully charged and use a battery maintainer when it will sit for several days. since you had the battery tested it must have been fully charged at some point. your draw seems kind of high and i would consider unplugging the ipod lines to see what happens to the draw if that was the last change you made before you noticed the problem. mine had an 80 ma draw that zapped my redtop (i have read on here it should be around 35 ma)and it never recovered. (it had been zapped before) but a new zone gold handled the load with no problem. i still would suspect the battery because a .02 amp discharge should not take a good, charged battery down over night.
good luck. you sound like you know what you are doing which was more than me!
whoops, i just read the you found the cluster switch on. never mind
Old Aug 9, 2008 | 07:58 PM
mavrick331's Avatar
mavrick331
The battery was seeing a 6 amp draw (with the gauge cluster on), which killed it overnight. At normal operation, as it is today with the Ipod to car still installed, it draws .34 amps in sleep mode.
When I had the battery checked, it was far from being fully charged, in fact I was worried that they would want to charge it first before testing it.
Since the install of the Ipod to car 6 months ago, I have gone up to 3 week weeks without running the car with no issues seen, I have never gone over 3 weeks without running the car. Is this harming the battery, i don't know?
Old Aug 9, 2008 | 08:36 PM
PerrinPhantomZ06's Avatar
PerrinPhantomZ06
Default Ipod
My vette has come up with a charge system fault error after not running it for 3 days and was slightly hard to start. This happend to me twice and only when i left my ipod hooked up in the car for extended periods of time.
I stopped leaving it plugged in and the problem went away, I can leave the car sit for weeks and restart with no issues..
Zach
Old Nov 30, 2016 | 06:06 PM
lewis butler's Avatar
lewis butler
1st Gear
yes. C6
To 03" Draining battery ??
