6 speed tranny question
Old Aug 5, 2008 | 09:31 PM
whylee's Avatar
whylee
Default 6 speed tranny question
I have a 04 coupe with a 6 speed, I just bought a Hurst shifter and on the box it states it fits 97-2000 T56 tranny.
On the instruction sheet it states it fits 97-04 T56 trannys. I have no idea which tranny is in mine, I did not know there was more than one 6 speed offered. How can I determine if this shifter is going to fit before tearing into it?
Old Aug 6, 2008 | 08:41 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
You have a T-56 tranny.
Here is link to wikipedia showing models installed on.
http://en.wikipedia.org/wiki/Borg-Warner_T-56
Old Aug 6, 2008 | 08:46 AM
TEXHAWK0's Avatar
TEXHAWK0
How did you get one with such an old box?
The Hurst shifter should fit all C5's, (and C6's even).
The base of the shifters are all the same. Some people have been installing C6 shifters in their C5's.
Old Aug 6, 2008 | 10:34 AM
whylee's Avatar
whylee
Thanks for the info, I guess it has been sitting in the warehouse for awhile. I bought it from Summit Racing (they are local here).
I also bought a shifter ****, also from Hurst but it does not fit the shifter.
The **** came with six different adaptors, but none of the adaptors will fit the shifter.
I cant believe Hurst would make a shifter that their own shifter ***** will not fit.
Old Aug 6, 2008 | 10:39 AM
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
Thats weird that the shift **** wont fit...I know the threads on this particular shifter are made to fit the stock **** which was obviously specified by GM back in the day...
Regardless, when you install the shifter, be sure to follow the directions regarding the "over-shift" set screws. Some people say set them properly with loc-tite, others say completely remove them. Pick one or the other but make sure you do it because if you dont, those setscrews rattle around and eventually block out certain gears....then you have to take apart the car again to set or remove them...
Old Aug 6, 2008 | 02:30 PM
whylee's Avatar
whylee
Thanks for the heads up
Old Aug 6, 2008 | 08:10 PM
simpleman68's Avatar
simpleman68
Mine didn't fit either, so I got a custom **** and used epoxy to hold it fast.
Of course it came out and was replaced with a C6 shifter and I'll never go back. The Hurst was way too notchy and stiff, even with the lighter springs installed.
Scott
Old Aug 6, 2008 | 08:20 PM
Novakain1970's Avatar
Novakain1970
The hurst shifter is bad ***, you will love it! Got one in my 04 and wont ever go back! Bolt it in, shouldnt have a problem!
Old Aug 6, 2008 | 11:09 PM
whylee's Avatar
whylee
Took the shift **** back to Summit, Hurst does not make the pistol grip shift **** in the 9/16X18 thread for the vette shifter now.
So I bought the white classic shift ****.
Now to get it installed, maybe this weekend.
To 6 speed tranny question
