FRAME Saver Question
Old Dec 31, 2001 | 11:47 AM
GR8-LIFE's Avatar
GR8-LIFE
Default FRAME Saver Question
The frame savers that I've heard people talking about - are they designed for the front undercarrriage, the ones that always get scraped when you go over those very curvy speed bumps or the long parking blocks that stop the car when you park?
Who has the lowest prices on these and how many hours can be allocated for someone to install (he'll be lowering the car at the same time.)
Old Dec 31, 2001 | 12:12 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: FRAME Saver Question (Ha-Ha)
Front undercarriage, for speed bumps, driveways etc. If they charge more than an hour you are getting ripped off. I think A&A is the only guy selling them, he has a good special that ends today on them. I am making my own as we speak. Total cost for mine. $12 dollars canadian. :D
Old Jan 2, 2002 | 01:32 AM
ZAP's Avatar
ZAP
Default Re: FRAME Saver Question (racer44)
I mounted them ( including welding ) in about 15-20 minutes. :cheers:
Old Jan 2, 2002 | 06:39 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: FRAME Saver Question (ZAP)
Like these,
Old Jan 2, 2002 | 10:30 AM
RoliO's Avatar
RoliO
Ditto for me. :)
Old Jan 2, 2002 | 11:16 AM
hottrodd57's Avatar
hottrodd57
mid america corvette sells some frame savers that do not have the wheel , they are 1/4 inch steel plate bent to the same shape as the skidplate, it is a bolted on, but I opted to welded mine on, I then ground the welds smooth, it looks factor. in the finished state. i never liked the little wheel style. j.v. :flag :cheers:
Old Jan 2, 2002 | 11:43 AM
Racer's Avatar
St. Jude Donor '11
Default Re: FRAME Saver Question (hottrodd57)
Wouldn't the wheels rolling on the ground sound better than 1/4 inch steel plate scraping?? :confused:
Old Jan 2, 2002 | 12:54 PM
GR8-LIFE's Avatar
GR8-LIFE
Default Re: FRAME Saver Question (wallstAL)
Like these,
They don't look very asthetically pleasing. Are they that visible???
Old Jan 2, 2002 | 01:41 PM
123Gone's Avatar
123Gone
I have them also. I drilled the hole, installed them, did not weld. Took me about 20-30 minutes start to finish. They are barely noticable. I would do it again.
Old Jan 2, 2002 | 01:51 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Like these,They don't look very asthetically pleasing. Are they that visible???
Barely from a distance!
Old Jan 2, 2002 | 02:13 PM
ambitin's Avatar
ambitin
I can't see mine at all. Remember, it is all black under there- so unless someone is shining a spotlight under your car. Also, if you lower your car, you have to lay on the ground to see them :cool:
No more scraping noise for me! My next vette, I'll buy them first thing so they don't get all scratched.
Lates,
Justin
Old Jan 2, 2002 | 02:15 PM
THRAP 42's Avatar
THRAP 42
Ha Ha,
For less than $10 bucks you can build your own. I bought some wheels, grade 8 bolts and a lock nuts from HQ. Installed them in the same area of the savers that are shown above, only difference is that my "custom spoiler rollers" don't have the bracket around the wheel and my wheels are cast vice rubber, but I don't use them for shock absorbers, just to get over the bumps, and the grade 8 bolts hold up very well.
I can get you some pics if you'd like, but it will take a bit.
later,
Old Jan 2, 2002 | 02:17 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: FRAME Saver Question (THRAP 42)
They are not very visible and definitely don't hurt anything having them on there. Just a little more protection.
Old Jan 2, 2002 | 02:23 PM
RoliO's Avatar
RoliO
Here is a pic of my A&A frame saver installed as well. Went on easy in about 10-15min. :)
GR8-LIFE's Avatar
GR8-LIFE
Ha Ha,
later,
Thanks for the tip. You don't have to knock yourself out for pics - I appreciate it though.
Old Jan 2, 2002 | 02:35 PM
GR8-LIFE's Avatar
GR8-LIFE
Default Re: FRAME Saver Question (RoliO)
Good View. But it looks as if the UnderCarriage Guards would still scrape.
Old Jan 2, 2002 | 03:55 PM
RoliO's Avatar
RoliO
I think those guards will scrape no matter what you do. :( Well unless you make the car look like a 4*4. :D
To FRAME Saver Question
