Vortex Filter FILTHY after 20K miles!!
Old Dec 31, 2001 | 01:53 PM
J99FRC's Avatar
J99FRC
Default Vortex Filter FILTHY after 20K miles!!
I would strongly recommend cleaning your vortex filter after 15K Miles (I'm lazy) in NORMAL driving conditions.. I must have removed about 1/4 cup of sand alone! Waiting to dry and re-oil and I'm sure she'll run better! :cheers:
Old Dec 31, 2001 | 01:57 PM
RG in Dallas's Avatar
RG in Dallas
Elite Member
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Vortex Filter FILTHY after 20K miles!! (J99FRC)
We recommend 10-15k on cleanings, depending on condtions. Here in TX, it's dusty:) so, 10k is what I clean at.
RG
Old Dec 31, 2001 | 02:07 PM
B. Stewart's Avatar
B. Stewart
I live in a similar environment and clean mine every 5k. It's good insurance!
Old Dec 31, 2001 | 02:55 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Default Re: Vortex Filter FILTHY after 20K miles!! (B. Stewart)
I have an extra filter, so I rotate them at every other 3500 mile oil change. I have yet to find anything at all in the filter. :)
Old Dec 31, 2001 | 05:15 PM
2001roadsterNBM's Avatar
2001roadsterNBM
What do you need to use to clean the Vortex Filter? K&N filter cleaner? TIA!
Old Dec 31, 2001 | 05:21 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: Vortex Filter FILTHY after 20K miles!! (2001roadsterNBM)
Cold air filters really do pick up some debris. I clean mine around every 7-10K also.
Old Dec 31, 2001 | 05:49 PM
Tracy's Avatar
Tracy
Default Re: Vortex Filter FILTHY after 20K miles!! (rschiltz)
FYI--After you've Simple Greened and thoroughly rinsed (from inside out!!) the filter, it takes about a year to dry before you can add the K&N filter oil. Maybe two years!!! So, plan ahead for this job. I recall that some guys used their shopvac or leaf blowers to speed up the drying process. I suppose putting it in the wife's convection oven, at a low 175, will help, too. But again, it's best to think of the filter as a wet towel that you can't wring or squeeze, so imagine how long that would take to dry and plan accordingly.
[Modified by tracy, 4:50 PM 12/31/2001]
Old Dec 31, 2001 | 06:20 PM
shockwave's Avatar
shockwave
Default Re: Vortex Filter FILTHY after 20K miles!! (tracy)
I cleaned mine at about 10K miles or whenever it starts to look dirty...
Old Dec 31, 2001 | 06:54 PM
BradSW's Avatar
BradSW
From: From San Diego to Bentonville, AR.....WTF was I thinking?!? Oh yeah, that free state thingy!
St. Jude Donor '15-'16
So what do you use to re-oil? Anything other than the K&N filter oil? Can I get something at the local auto parts store?
Old Jan 1, 2002 | 10:04 AM
J99FRC's Avatar
J99FRC
Default Re: Vortex Filter FILTHY after 20K miles!! (BradSW)
You can go to Pep Boys or O-Rielly to get the re-charge kit... The filter is the same as a K&N filter and is fairly easy to clean.. Kit cost about $11... And no, you don't hafta let it dry for a year..
Here's how I did it...
Use a brush/toothpick to get the small rocks out of the filter or any large objects.. Next, spray the filter cleaner HEAVILY on the filter in and out and let sit for about 10 minutes.. Rinse thoroughly from the INSIDE OUT with low pressure until the water is nice and clean.. Next, set outside in the sun for about 3 hours.. After it dries a little, spray the re-charge oil (Now's it an aresol spray) only 1 pass around the filter, don't over do it.. Let sit for about 20 minutes and re-install... Next time I will clean every other oil change!! :cheers:
Old Jan 1, 2002 | 10:46 AM
XTrooper's Avatar
XTrooper
At 20K even the stock air filter in the stock airbox would be dirty, so it would stand to reason that a cold air filter would need more frequent attention.
[Modified by XTrooper, 2:57 PM 1/1/2002]
Old Jan 1, 2002 | 12:53 PM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Every 5K here.
It's an EDD and we have a lot of trash on the road around here!
Its easy to do with the Vortex too!
Old Jan 1, 2002 | 01:35 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Re: Vortex Filter FILTHY after 20K miles!! (ALLTHROTTLE&NOBOTTLE)
Here on Long Island I have a ton of sand at 4000 I now due as stated above rotate filter at oil change or clean before track event.
Old Jan 1, 2002 | 05:40 PM
Plastic Pig's Avatar
Plastic Pig
Live Free or Die
From: One thing is for sure this kind of discourse and BS would not be tolerated on the NCRS forum. Ohio
Default Re: Vortex Filter FILTHY after 20K miles!! (John Shiels)
Mine is filthy after 5k miles, can't imagine waiting til 15k :eek:
To Vortex Filter FILTHY after 20K miles!!
