RPM singal wire?
Old Aug 8, 2008 | 02:57 AM
TurboTravis's Avatar
TurboTravis
Default RPM singal wire?
Guys, I'm just curious where the easiest place is to pick up an RPM signal for my wideband. Thanks!
Travis
Old Aug 8, 2008 | 04:20 AM
LoneStarFRC's Avatar
LoneStarFRC
Can't recall the specific details, but there is a white wire that gets tapped into under the driver's side dash that a lot of guys are using for their shift light rpm trigger signals. I think it leads to the DIC . Maybe you need something more convenient on the engine side of the firewall though.
Try a search or maybe someone else can jump in to help.
Old Aug 8, 2008 | 05:16 AM
TurboTravis
Thanks. Either side of the firewall works for me, but driver side is better. Search isint working well for me..
Old Aug 8, 2008 | 05:23 AM
TurboTravis
FYI, this is on a 2001 z06.
Old Aug 8, 2008 | 09:36 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
quote from Robert "
The factory tachometer output can be found on the Powertrain Control Module (PCM) found in the passenger tire well. The PCM has two 80 pin connectors, with the one closest to the firewall being called the "Blue" connector by GM. The other connector is called the "Red" connector. These connectors have a plastic hold down that snaps off, be careful.'
same reply in F/I for you
Old Aug 8, 2008 | 11:42 AM
LoneStarFRC
Darn search function still having hiccups after the recent upgrade.
PM Z06-JIM. He had a thread with pics awhile back on his shift light install.
HTH
Old Aug 8, 2008 | 12:08 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
It's pin 10 (white wire) on the pcm. You can also pick it up on the coil pack connector. Hit up Beer99c5 for that pic, I don't have it with me.
Here's a pic of the pcm. The Z28 pictured is the same, just mounted sideways. Now, why is it you need a RPM pick up for a wideband?
To RPM singal wire?
