Gas Guage reading empty
Old Aug 9, 2008 | 06:41 AM
drea02z's Avatar
drea02z
5th Gear
Default Gas Guage reading empty
I have a 02 zo6 with 30 000km which i bought just over a month ago.
This car is fantastic.
A problem had just come up last night, the gas needle fell from full to empty in a second and the check guages light lit up the dash. I know i have a full tank of gas and I'm sure there is no leak.
Does anyone now where i should start looking before i bring the car to the dealer?
Thanks for any help.
Old Aug 9, 2008 | 07:03 AM
jdmvette's Avatar
jdmvette
Night Owl for life
it's one of the most common problems with the c5. no big deal.
you can try turning the engine off then turning it on again. sometimes that's all it needs to fix it...until the next time.
Old Aug 9, 2008 | 07:10 AM
Mark2ooo's Avatar
Mark2ooo
What kind of gas did you put in it? If it was cheep gas something other then your main companies they tend to mess up the gauge. If I put sunoco in my tank I dont have a problem but if I put other gas in I will drive 10 min before my gauge goes to empty. If you put techron in the gas it also helps the problem.
Old Aug 9, 2008 | 07:13 AM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
You most likely have a situation that has an easy fix. It's fairly common. Apparently the fuel sending unit in our cars is fairly sensitive and if your not using top tier fuels this can happen. It's happened to me and mine was easily corrected by filling up with Chevron fuel. Chevron fuel has an additive called Techron that will solve your problem 90% of the time. If Chevron isn't available you can purchase the additive Techron at most auto parts stores. Dump it in your fuel tank and it should fix the problem. Mine started working after about 15 miles of driving. Now every 6 months or so I add a bottle of Techron and fuel up with Chevron when I can.
Here's a thread on Techron. You can also read through several other threads on the subject by using the search function and typing in Techron.
http://forums.corvetteforum.com/show...hlight=techron
Old Aug 9, 2008 | 08:32 AM
rws.1's Avatar
rws.1
3 posssible problems.
1. MOST COMMON A fouled fuel sender... cause gasoline with insufficent detergency... long term fix buy a better gasoline see www.toptiergas.com
Short term fix.... use 2-3 tankfuls of a good fule system cleaner
Shell V-Power, BG 44K, SeaFoam, ValvolineSynpower, Techron
2. Occassionaly A bad/corroded ground. Inspect body grounds cleana s required
3. A failing fuel sender... replace.... Gas tank needs to be dropped, fuel sender replaced.
Old Aug 9, 2008 | 12:41 PM
p_dubya's Avatar
p_dubya
I was having this problem consistinetly and i was having to put Techron in almost every tank...that gets expensive! As soon as i put the Techron in the needle would start working again within a mile of driving!
I switched to a top tier fuel and I haven't had the problem once in the last few months that I've been using Shell exclusively.
Good Luck.
P.S. Good to see some Canadian content on here. I'm from Thunder Bay myself! It sux you only get to drive the C5 for about 3 months though!
Old Aug 9, 2008 | 02:47 PM
dmoore's Avatar
dmoore
Seafoam and Techron by Chevron is your friend! All can be purchased at your local favorite automotive store or Wallyworld. Make sure to use a high quality gas!
Before you spend tons of money putting in new sending units, clean the ground contacts, sometimes that will also clear up the issue.
Old Aug 9, 2008 | 02:51 PM
dmoore's Avatar
dmoore
If you need a new fuel sender check with some forum members first, there are a couple that can get them for a cheaper price than what your local dealer is going to charge you, which is extremely expensive!
Old Aug 9, 2008 | 03:08 PM
drea02z's Avatar
drea02z
5th Gear
Thanks for all the advise.
I can't find Techron or seafoam. I guess its not sold in Canada. I will try some fuel system cleaner and cross my fingers. Also, will be filling up at Shell for now on.
Again, thanks for all the help.
Old Aug 9, 2008 | 05:21 PM
dmoore's Avatar
dmoore
Do you have Wal-Mart there? They carry Techron.
To Gas Guage reading empty
