Hood Light
Old Aug 9, 2008 | 10:31 PM
eddies06's Avatar
eddies06
5th Gear
Default Hood Light
What is the best way to remove the bulb under the hood on a 06
Thanks for some help
Old Aug 9, 2008 | 10:55 PM
byronhunter's Avatar
byronhunter
Default Lamp, underhood
From the manual------Remove the underhood lamp lense cover. Grasp the lense cover and depress the upper and lower locking tabs to release.
You are in the C5 Tech section, but you said "06." So I assume you meant Z06. If you meant 2006 year model, it might be completely different!
