splice packs
Old Aug 10, 2008 | 11:26 AM
mcgilles's Avatar
mcgilles
Default splice packs
anyone have a suggestion of how to build new splice packs? I have several situations where I need to connect a number of wires together. I want them to be individually removable, no crimping isn't a good idea. screw terminals or pressure terminals which are removable would be best. it needs to be waterproof of course since its under the hood. something like the C5's original splice packs might work perfectly, looks like it would require a small spade terminal on each wire. it would just have to be packaged up well to be water proof. or an internally connected terminal strip? just wondering if anyone else has figured something out.
Old Aug 11, 2008 | 08:57 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
Some of the auto parts stores carry water tight connectors similar to the the Delphi ones found in the corvette. If you are going to be doing a lot of electrical work this company "Waytek" carries everything.
www.moroso.com
