C5 offset question
Old Aug 10, 2008 | 09:13 PM
Stallionvette's Avatar
Stallionvette
Default C5 offset question
Hello! Will the 20" wheels with 40mm offset give any problem? Thanks for the tip!
Old Aug 10, 2008 | 09:23 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
If they're no more than 8.5" wide, no problem.
Without a width dimension, no one can answer an offset question.
Old Aug 10, 2008 | 11:00 PM
Stallionvette
They are 20X8.5 for the front and 20X10 for the rear. Thanks again!
Old Aug 11, 2008 | 09:25 AM
Ted J's Avatar
Ted J
I recently ran across these two sites that ROCK for figuring out tire sizes and wheel size and offsets. The first site is a simple sites but oh so powerful in being able to visualize what's going on and it gives you the difference in speedo speed that will occur and tells you how much more the tire will stick in or out etc. Very powerful and impressive site!
http://www.wheelsmaster.com/rt_specs.jsp
On this next site you can use it to look up some wheel specs as well. I can't find a lot of GM on there but for my import car I was able to find some factory wheel specs on there. Just posting it up for there's some good info on that site.
http://www.wheelspecs.com/
Old Aug 11, 2008 | 12:39 PM
Stallionvette
Thanks, Ted J
To C5 offset question
