CAI Air Filter
Old Aug 13, 2008 | 02:03 PM
weinerschizel's Avatar
weinerschizel
Default CAI Air Filter
I happen to have a K&N air bridge installed in my 99 FRC. It currently runs to the stock air box. Then the lid of the air box is cut off.
I'd like to have a full out cone filter setup on there. So I looked at purchasing the filter from K&N but discovered it requires modifying the radiator housing to mount the filter.
I don't like that idea. Does anybody know if, you can purchase a drop in cone / cloth filter setup that works with the stock air box mounts?
Or something at least that doesn't require modifying / cutting up the car to put it in.
Thanks!
Old Aug 13, 2008 | 03:15 PM
LoneStarFRC's Avatar
LoneStarFRC
Thanks!
The Blackwing uses the factory mounting points on the front crossmember and the factory AIR tube plugs right into it also. No modifications to the radiator housing/shroud either.
HTH
Old Aug 13, 2008 | 03:49 PM
JCamaro's Avatar
JCamaro
I like the idea of that little bit of cold air the K&N modified shroud provides.
But the Blackwing will work just fine....
JC
To CAI Air Filter
