Hood water seals?
Old Jan 2, 2002 | 12:02 AM
C5 in 2002's Avatar
C5 in 2002
Default Hood water seals?
I just installed the RM twin flow filter and I know that I have seen something about getting an additional hood seal to keep water off of it, I did a search and didn't come up with anything :confused:
Thanks,
Richard
Old Jan 2, 2002 | 12:09 AM
99 Corvette's Avatar
99 Corvette
Default Re: Hood water seals? (C5 in 2002)
Check in the mall section they are around $12. They won't do anything for performance but will keep water off the filters :cheers:
Jerry
Old Jan 2, 2002 | 12:10 AM
c5rocket's Avatar
c5rocket
8th Gear
I ordered one of the factory hood seals that are on the right/left side of the hood, cut it to length and installed it on the front.
Old Jan 2, 2002 | 12:38 AM
C5 in 2002's Avatar
C5 in 2002
Default Re: Hood water seals? (c5rocket)
Thanks, I guess I am going to have to make sure there is no water on the hood when opening as well because looking at it the water would drip right on to the twin flow filter. I have an extra factory hood seal that I ordered thinking that it would be the right one :D :D
Old Jan 2, 2002 | 07:17 AM
Drop_Top_Dave's Avatar
Drop_Top_Dave
Kid Rock Fan
Cruise-In IV Veteran
You can see it here at the forum mall
http://store.yahoo.com/corvetteforum/zip-x-777-sc.html
Dave
Old Jan 2, 2002 | 07:40 AM
Joe C's Avatar
Joe C
ditto!!! much better quality than the aftermarket seals (JMHO) i originally purchased an aftermarket seal while at mid-america funfest last year. well the cheap double sided tape didn't hold up very well multiple washings. anyway, i went to my local chevy dealer and purchased the same seal used on the RH/LH hood opening, trimmed to fit and installed on my 2000 coupe. works great, looks factory, and looks great!!!
Old Jan 2, 2002 | 09:17 AM
Tom/99's Avatar
Tom/99
I got mine thru Mid America. It really makes a difference in keeping the engine compartment clean.
Old Jan 2, 2002 | 11:19 AM
NewfieC5's Avatar
NewfieC5
How expensive??
Old Jan 2, 2002 | 12:22 PM
carpe dm's Avatar
carpe dm
You can get the seal at auto parts stores and use 3M adhesive.
Old Jan 2, 2002 | 01:32 PM
motoracer's Avatar
motoracer
I got the aftermarket hood seal and removed the tape that came with the seal.
I then put my own double sided take on both sides and then attached the seal. Works well so far. I have had it on for about 3 months.
Old Jan 2, 2002 | 01:58 PM
Tiger Shark's Avatar
Tiger Shark
Thanks,
Richard
They're all in the "archived" section. You have to select "archive" instead of "current" when performing your search. Here's one... http://forums.corvetteforum.com/zerothread?id=195746
:cheers:
To Hood water seals?
