Need your help
Old Aug 17, 2008 | 10:59 AM
brit2001's Avatar
brit2001
Default Need your help
I have a 01 auto. I recently put 3.42 gears in the rearend and while it was apart I put a 3200 stall to handle more power later. The car was dynoed at 347 at the rear wheels right now. My problem is I drive alot at speeds under 40 mph. I work on Hill AFB and there is a hill I go up to get to work. The car is in drive and its pulling about 1200 rpm and the torque convert is locked up. The car will on sometimes start to bog and shutter like the torque converter can't decide weather it wants to stay locked or unlock. If I give it a burst of throtttle it goes away. Do you think I need to increase trans pressure? Hope this makes sence. Thanks in advance Laurence.
Old Aug 17, 2008 | 11:24 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Did you reprogram the PCM after installing the 3.42 differential?
Old Aug 17, 2008 | 11:53 AM
brit2001's Avatar
brit2001
Yes, I did , than I took it to Charlie at RPM and had it tuned.
To Need your help
