lowering my 99 c5
Old Jan 2, 2002 | 11:49 AM
bovette's Avatar
bovette
Default lowering my 99 c5
Please excuse my ignorance, I want to lower my C5 about 1 inch all the way around. My car has the z51 package. What exactly do I need to do? Do you reccommend getting new shocks and coil-overs? Thank you for all your help
Old Jan 2, 2002 | 12:00 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: lowering my 99 c5 (bovette)
Best thing to do is, type "lowering" in the search box and you will find lots of threads with detailed instructions, pros and cons and opinions on this very subject. There is lots of info on this subject. :yesnod: :cheers:
Old Jan 2, 2002 | 02:10 PM
MilYellow02's Avatar
MilYellow02
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
I will end this thread by saying.......Cut 2/3 of the bushings in front and turn bolts all the way up, get the longer bolt in the rear and adjust the rear until happy......this should give you about an inch. If you don't like your ride after awhile get the Bilstein Sport shock for around $299......Hope this helps :seeya
Old Jan 2, 2002 | 02:11 PM
BLISS's Avatar
BLISS
Cruise-In II Veteran
Default Re: lowering my 99 c5 (MilYellow02)
..... or buy Coil Overs and call it a day :D:D:D:D
j/k
Old Jan 2, 2002 | 02:16 PM
ambitin's Avatar
ambitin
ditto everything that milyellow02 said (I have 99 FRC with Z51 also...)
Old Jan 2, 2002 | 02:19 PM
GR8-LIFE's Avatar
GR8-LIFE
I'm lowering pretty soon also. I don't intend to cut front bushings - most say that the most you'll get in the front without cutting is 3/4". The back I will lower probably 1.25 inches. I'm definietly getting the Billsteins. If I were you, I would invest in the Frame Savers because there will most likely be some time when youy are scraping. I hear from lots of guys that they wish they had purchased the Frame Savers long ago.
Old Jan 2, 2002 | 02:22 PM
THRAP 42's Avatar
THRAP 42
Bovette,
You have mail w/lowering instructions.
later,
Old Jan 2, 2002 | 02:25 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: lowering my 99 c5 (THRAP 42)
Also, it might take a few tries to get it exactly where you want it.
Old Jan 2, 2002 | 02:34 PM
bovette's Avatar
bovette
Thanks Guys for all the help!
Old Jan 2, 2002 | 10:55 PM
corvette dave's Avatar
corvette dave
Bo,
Don't get hung up on 1". 3/4" may look fine to you.
Lower the car with the stock bolts front and rear and see how you like it after a few weeks. At this point you have not lost anything. You will probably get about 3/4" from this method.
If this is not low enough, cut the front bushings and get longer bolts for the rear. Never, never cut the rear bushings.
My last car was a '99 C5 with Z-51 suspension and I lowered it by cutting the front bushings and getting longer bolts for the rear.
The ride suffered a little over stock but not much.
Good luck with it.
To lowering my 99 c5
