Quick tire question?
Old Aug 18, 2008 | 02:14 PM
XXXLTRP's Avatar
XXXLTRP
Default Quick tire question?
Can I run 275-40-17 in the front and 295-35-18 in the rear? The height difference between the two is .4. Is that enough difference to not cause havoc on the traction control system? I thought I read somewhere the difference needed to be .5 or greater to avoid issues with the traction systems. Help before I drive Luke@tirerack crazy!
If needed it's a '99 FRC with '01 Z06 wheels.
Old Aug 18, 2008 | 04:12 PM
Oldvetter's Avatar
Oldvetter
I have always heard that you need 1/2 inch difference for traction control and active handling to work. Stock tires are 1 inch difference.
Old Aug 18, 2008 | 04:18 PM
wamara's Avatar
wamara
Cruise-In II Veteran
Lots of people here run that combination with no reported problems, since some tire brands don't come in the 265/40 front OEM size.
Old Aug 18, 2008 | 05:02 PM
XXXLTRP's Avatar
XXXLTRP
I'm sure I've read that as well. After a while all the stuff I read runs together. If I can get a few members to chime in that are running that combination without issues I can go ahead and order some new rubber.
Old Aug 18, 2008 | 06:31 PM
rws.1's Avatar
rws.1
that's the combo I run... no issues over the last 2 summers...
To Quick tire question?
