Heads and Cam vs Cam only
I love the cam and it made decent power considering it needed a tune badly (361-rwhp). Though just a few months after installation I was really wishing I had waited and done heads too.
I had 4.10 gears in that car too. I wish I'd stayed with the stock 3.42.
We do a whole lot of cam only packages and we usually end up adding the heads at a later date. Its really not a huge deal to split them up for budget reasons. If money is not an object we always recommend doing them together to save a few dollars on the tuning. If the customer is on a budget we will do a cam only first and then we can always add heads down the road.
The next year I went with AFR 205 heads and a Fast 90 intake manifold. This increase my rwhp to 423. My car is much faster but does things like spinning the wheels on the highway when passing someone (speeding-up but not really trying to go fast). The gas mileage decreased ~10%.
I could have saved money doing everything at once had I known what I wanted. With just the cam and headers the car was a great daily driver. With the heads it turn into a real muscle car, but occasionally that has the unintended consequences of having the car do things that I was not planning (spinning sideways, spinning the tires at high speeds, fishtailing, etc).
If I were to do it all over again I would probably either stay at the initial stage, or stick with the 3.15 gears if I did the H/C. Since the quarter mile isn't my focus this would help keep the car a little more under control.
Either way, it sure beats stock performance.
Below is the dyno showing stock (with bold-ons), cam only with headers, and H/C with Fast 90.
http://www.comp-soln.com/Dyno3Run.jpg
It will only be a matter of time before the mod bug bites again. I started with just a cam but in the end I wanted more. If you do the work yourself breaking it up is no big deal. If you're paying someone else I'd advise to just save and wait to do both at the same time to save on labor cost.
So, doing a little at a time may cost a bit more, but the personal joy of modding is greatly enhanced and extended.
Consider this; if you do the heads next year, you get your modding "fix" for next year. If you do the heads now, then what will you do to satisfy your modding "habit" next year? You WILL do something, and it WILL cost.
So,,,, maybe incremental modding is actually cheaper, and more rewarding???
Now, how much HP did you say those heads made? Time for my next "fix".
DG
If you don't have LS6 intake -- do that or FAST next.
I know it sounds backwards, but do the headers and heads at a later date as the headers fall in with the heads off.
Then do gears and drivetrain beef.
There's 3-4 years worth of modding fix.
I'd love to have that exact set up, not looking for anything too radical either. Plz let me know how its possible, or what exact parts did you use?Thanks... Keep the thread going guys..
