B0 RFA code! Any suggestions?
Old Aug 19, 2008 | 09:17 PM
gaklid's Avatar
gaklid
Default B0 RFA code! Any suggestions?
Neither my keyless entry or tire pressure monitoring works. When I try to link my new or old fobs with the car, the DIC doesn't even complete the the learning process. Anyhow, how do check the receiver in the car? People have said the receiver is behind the drivers seat, but has anybody actually SEEN it? Exactly where is it? BTW, I've checked the ground near the battery, and it looks good....Any suggestions?
Old Aug 19, 2008 | 10:50 PM
gaklid's Avatar
gaklid
I found the unit, unplugged it and I have 12 volts at the connector. Any help?
Old Aug 19, 2008 | 11:58 PM
BlackZ06's Avatar
BlackZ06
Install the RFA back in the car.
You need to display your DTC data. If you don't know how to do it go here ....
https://www.corvetteforum.com/techti...D=26&TopicID=1
When the AUTOMATIC display completes it will enter MANUAL mode. In that mode display and write down what codes you have.
A code looks like this ...... P 1234 C
The first letter will be either a P, B, C, or U ..... indicating which system the code is for.
The following 4 numbers are the code
The last letter will be a C or an H (sometimes both).
Post the ENTIRE code (as in the example ..... P1234C), and list ALL the codes found.
To B0 RFA code! Any suggestions?
