next step for A/C problem??
Old Aug 19, 2008 | 10:39 PM
kid81's Avatar
kid81
Default next step for A/C problem??
I have the dreaded ac blowing out of all the vents...this is what ive done so far... I replaced the hose from the intake to the vaccum valve, changed the vaccum valve, changed the hose from the vaccum valve to the canister. Next I follow the OEM tube into the passanger cockpit and made sure it was hooked up to the purple vaccum hose and all that looked good. when I unpluged all the hoses to change them, I heard a pressure release so I believe that there were no leaks. Guess what?? it did not fix the problem.. What would be my next step to a fix?? I did many searches but could not come up with the next step...
Old Aug 19, 2008 | 10:49 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Do you have the digital or analog A/C controls? You can get a vacuum gauge and make sure you have vacuum making it's way to the control panel and leaving it as well.
Old Aug 19, 2008 | 11:06 PM
kid81's Avatar
kid81
daul zone ac unit..... where would I start the vaccum check process..
Old Aug 19, 2008 | 11:35 PM
bestvettever's Avatar
bestvettever
Default AC Problems
Hi, if you are sure that the main vacuum line is properly attached to the back of the intake manifold and the other end is properly attached to the check valve and cannister, then goes into the car and is attached to the vacuum block which then goes to the control head, and all of these connections are good, then it could be your control head, or the mode vacuum actuator solenoid or motor. Below is the troubleshooting diagnostic. When you find the problem , and if you need instructions on how to fix or replace something, post and let us know. FWIW if I had to make a guess, I'd guess the control Head is bad, they are known to go bad.
Good Luck--SEE BELOW
Air Delivery Improper
Test Description
The numbers below refer to the step numbers on the diagnostic table.
5, Test the HVAC control module front defrost button and the mode button for proper operation.
6, Can you hear the recirculation door switch from outside air to the recirculation position.
8,Tests the HVAC control module for the proper commanded state. The ON/OFF positions for each mode are as follows:
FLOOR POSITION -- solenoids 1 and 5 OFF, solenoids 2 and 3 ON, solenoid 4 ON or OFF.
VENT POSITION -- solenoids 1 and 3 OFF, solenoids 2 and 5 ON, solenoid 4 ON or OFF.
VENT/FLOOR POSITION -- solenoids 1, 3 and 5 OFF, solenoid 2 ON, solenoid 4 ON or OFF.
FLOOR/DEFROST POSITION -- solenoids 1, 2, 4 and 5 OFF and solenoid 3 ON.
DEFROST POSITION -- solenoids 1 and 3 ON and solenoids 2, 4 and 5 OFF.
10, Tests the solenoid circuits for an open or short.
11, Tests the solenoid circuits for an open or short.
12, Tests the vacuum control assembly solenoids.
13, Tests for a constant ground, constant voltage and an open on the solenoid control circuits.
Step
Action
Values
Yes
No
Schematic Reference: HVAC Schematics
Connector End View Reference: HVAC Connector End Views
DEFINITION: Air does not flow correctly from the air distribution outlets.
1
Did you perform the HVAC Diagnostic System Check?
Go to Step 2
Go Diagnostic System Check - HVAC Systems - Automatic to
2
Start the engine.
Place the blower motor switch in the OFF position.
Is the blower motor OFF?
Go to Step 3
Go to Blower Motor Always On
3
Place the blower motor switch in each speed position.
Does the blower motor operate in any of the speed positions?
Go to Step 4
Go to Blower Motor Inoperative
4
Does the blower motor operate at the desired speed in each speed position?
Go to Step 5
Go to Blower Motor Malfunction
5
Install a scan tool.
With a scan tool, observe the Mode Button parameter in the Heating and Air Conditioning data list.
Activate the mode switch.
With a scan tool, observe the Front Defrost Button parameter in the Heating and Air Conditioning data list.
Activate the front defrost switch.
Does the scan tool indicate that both the Mode Button and Front Defrost Button parameters change state?
Go to Step 6
Go to Step 15
6
Place the blower motor switch in the maximum speed position.
Place the mode switch in the vent position.
Place the outside air switch in the OFF position.
Place the recirculation switch in the ON position.
Does the recirculation door operate properly?
Go to Step 7
Go to Air Recirculation Malfunction
7
Place the mode switch in each mode position.
Place the defrost switch in the defrost position.
Does the air flow from the correct air distribution outlets in each mode position?
Go to Testing for Intermittent and Poor Connections in Wiring Systems
Go to Step 8
8
With a scan tool, observe the Vacuum Solenoid parameters in the Heating and Air Conditioning data list.
Place the mode switch in each position.
Does the scan tool indicate that each observed solenoid parameter changes to ON when the corresponding mode is activated?
Go to Step 9
Go to Step 15
9
Turn OFF the ignition.
Disconnect the vacuum control assembly.
Turn ON the ignition, with the engine OFF.
Probe the ignition 3 voltage circuit of the vacuum control assembly with a test lamp that is connected to a good ground.
Does the test lamp illuminate?
Go to Step 10
Go to Step 16
10
Place the mode switch in the VENT position.
Place the RECIRC air switch in the RECIRCULATION position.
Measure the voltage between the ignition 3 voltage circuit and solenoid circuits 1, 2, 3, 4 and 5 of the vacuum control assembly connector.
Does solenoid circuits 1 and 3 measure 0 volts and solenoids 2, 4 and 5 measure 12 volts?
Go to Step 11
Go to Step 13
11
Place the DEFROST switch in the DEFROST position.
Does solenoid circuits 1 and 3 measure 12 volts and solenoids 2, 4 and 5 measure 0 volts?
Go to Step 12
Go to Step 13
12
Remove the vacuum control assembly.
Measure the resistance between the ignition 3 voltage circuit pin and solenoid circuit pins 1, 2, 3, 4 and 5 of the vacuum control assembly.
Is the resistance for each solenoid between the specified value?
70 to 110 ohms
Go to Vacuum Control System Diagnostic
Go to Step 14
13
Test the appropriate control circuit for an open, short to ground or short to voltage. Refer to Circuit Testing in Wiring Systems.
Did you find and correct the condition?
12 V
Go to Step 19
Go to Step 15
14
Inspect for poor connections at the harness connector of the vacuum control assembly. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 19
Go to Step 17
15
Inspect for poor connections at the harness connector of the HVAC control module. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 19
Go to Step 18
16
Repair the ignition 3 voltage circuit of the vacuum control assembly for an open or high resistance. Refer to Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 19
17
Replace the vacuum control assembly. Refer to Vacuum Control Assembly Replacement .
Did you complete the replacement?
Go to Step 19
18
Replace the HVAC control module. Refer to HVAC Control Module Replacement .
Go to Step 19
19
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
To next step for A/C problem??
