Changing springs in Hurst shifter
Old Aug 20, 2008 | 08:35 PM
nickolbag's Avatar
nickolbag
Default Changing springs in Hurst shifter
Any write up? Or is it pretty straight forward?
Old Aug 20, 2008 | 10:17 PM
TEXHAWK0's Avatar
TEXHAWK0
Just remove the hex head screws on the top of the shifter base, change the springs, and re-install the screws using loctite on the threads.
I think the Hurst instructions say to reinstall the screws approx. 3-1/2 turns as a starting point for an adjustment.
You can also leave the existing springs in place, and make a minor adjustment by turning the adjusting screws up to one full turn in either direction from the factory.
Old Aug 20, 2008 | 10:19 PM
Patches's Avatar
Patches
They may go flying if you don't keep some downward pressure on the setscrews as you unscrew them. The springs are pretty strong and there is usually one inside the other if they've never been removed. Other than that, straightforward. I always used just one light spring on each side and the side loads were still adequate.
Old Aug 20, 2008 | 11:28 PM
nickolbag's Avatar
nickolbag
Thanks guys
I put the stiffer springs in the shifter. Hopefully this is the feel I'm looking for at the track.
To Changing springs in Hurst shifter
