please help with crank pinning
Old Aug 20, 2008 | 09:07 PM
stlchevy97's Avatar
stlchevy97
Default please help with crank pinning
i have a paxton sc600 kit im putting in. i got the balancer bolt off but need detailed instructions on how to pin the crank. i have the pin and drill bit but dont know where to drill the hole. also why am i doing this? after the hole is drilled i just slip the pin in there and tighten the bolt down? someone please help i cant find instructions anywhere. thanks
casey
Old Aug 20, 2008 | 10:03 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
casey
No place real special as long as the balancer is not keyed. JUst bolt up the pin block and drill to the right depth. Put som duct tape on the drill bit to limit the depth.
Old Aug 20, 2008 | 10:11 PM
Patches's Avatar
Patches
The crank pulley is pressed on and not keyed so likely to spin loose in high-torque applications like supercharging an LS1. To prevent this, a method was devised to simulate a keyed pulley/shaft setup by drilling a hole that spans across the crank snout and pulley and inserting a dowel pin to lock the two together.
Here's a pinning tool with a drill bushing in the collar to guide the drill bit.This is screwed into the crank after the pulley is installed.
Here you can see the dowel pin after insertion.It's at `12 o'clock on the pulley hub/crank interface. The crank bolt is then inserted and torqued in place.
Old Aug 20, 2008 | 10:15 PM
tiojames's Avatar
tiojames
Good explanation!
Old Aug 20, 2008 | 10:32 PM
stlchevy97's Avatar
stlchevy97
thank you all very much for fast detailed explanation and pictures. it helped tremendously and i got my crank pinned
To please help with crank pinning
