My PCM was recently replaced after a leaking battery ate it. I guess the dealer failed to reprogram. What kind of problems can this cause? Thanks for the info, it is appreciated! :yesnod: :lol:
If you're AIR BAG light is lit (and my guess it's what started this), the Air Bag system is disabled. For safety's sake, I'd get it fixed as soon as practical, but other than that, operation and performance are not affected.
No, I don't think the airbag light is on. I'll check tomorrow. I have had gas guage problems in the last several days. That's why I pulled the codes. I have a 10-PCM P1431H that's related to that problem.
I just checked, the airbag light came on for several seconds after starting the engine but went off and stayed off. I believe this is normal :confused:
When you pulled the codes, was there an "H" or "C" after the number. If there was an "H", there is a possiblility that the code was set by the tech. He could have corrected it but not cleared it.
