Need help with engine #s
Old Aug 22, 2008 | 01:33 PM
MILESTONE#001's Avatar
MILESTONE#001
Default Need help with engine #s
Where do I find the engine # and how do I tell what year it is. I bought a 98 and was told that they put a 2001 engine in it and want to know how to tell if they did or did not. Thanks
Old Aug 22, 2008 | 04:21 PM
byronhunter's Avatar
byronhunter
Default #'s
You want a PIA job? This is from '02 (and '02 service manual). The # is stamped on the rear edge of the block on the left (driver) side. Only visible from the bottom. If your car has pup cats like mine, look just above the one on the left side. This is on the flange that the bell housing bolts to. The first pad you see has a mystery (to me) #. Look on up above it, might have to move a wireing harness out of the way, I did. It's a 9 digit # which should match the last 9 digits of your vin #. I sure hope this helps you, and maybe someone else!
Oh, the second # of the 9 digit # is the year. Example, on my '02, the second # is "2"
