High Voltage on DIC throwing codes like mad!
Have a Red Top 900 cca battery that is 2 years old. Went to Auto Zone and the guy swapped me for a brand new one even though mine showed to be a good battery (a friend).
That was not the problem. Went and bought a new still in box Valeo 145 Amp 14 vdc alternator w/ clutch pulley ($617.00).
Now it charges at 13.5v running and battery is 12.6v when not running.
PROBLEM!
Getting HIGH VOLTAGE on DIC. It is so high it trips my hvac lamps and cluster lamps in gauge bezel for protection I guess. When it gets down to about 15.5v the gauge lamps come on as well as all the gauges.
I have never cleaned the grounds on this vette sice I bought it new. I should have done this first before spending 617.00 buck on an alt.
Also, my left blinker blinks 3 to 4 times faster than normal. The right blinker is fine. No bulbs are out. Is this a clue?
One more thing, Do I need to disconnect my neg. battery cable before disconnecting the front 2 grounds near the headlights on the frame?
This is my daily driver and cannot get to work. Help needed.
Thanks,
Darrell-
Also make sure that all the cables are tight and clean at the batt, alt, starter lug, and the fuse block underhood.
You should check what the output from the alt is with a voltmeter at the large red output wire to confirm that the guage is seeing an actual overcharging event. If it doesn't match the guage, there is a problem with the ipc. Then measure the volts at the sense wire, it should read battery voltage with the engine off, and charging voltage with it running. If it reads true, you probably got a bad regulator in the new alt.
Good luck
Here are the correct part numbers for the alternator .....
1997 - 2000 .... part number... 10316182
2001 - 2004 .... part number... 10353440
Check that you have the correct part installed, the wrong part will definately cause problems.
Good luck
The sense wire is which one on the alt.? Where does the other lead from my meter go to? Sorry, I am new to this.
The IPC is a module that controls the cluster gauges and lighting?
Let me clean the grounds I can get to under the hood including the one at the fuse block near the battery first. Be back this afternoon to report about it.
Thanks,
Darrell
The sense wire is which one on the alt.? ( should be the lower pin on the 2 pin connector, neg lead to any ground), (You could also check the upper pin which should be the signal to the pcm and record that value)Where does the other lead from my meter go to? Sorry, I am new to this.
The IPC is a module that controls the cluster gauges and lighting? (Yes instrument panel cluster) The alt sends a signal to the pcm which signals the ipc which if high will throw the code and signal the dic.
Let me clean the grounds I can get to under the hood including the one at the fuse block near the battery first. Be back this afternoon to report about it. (Make sure the connection on the starter lug is good solid, and clean, an intermittent connection there will definitely play with the charge signal to the alt).
Thanks,
Darrell
If the grounds dont fix it, I will have GM recheck the alt again.
Thanks,
Darrell
Thanks,
Darrell
The PCM monitors the vehicle's electrical system. It is looking for occasions where the vehicle electric system is either running on a voltage that is to high, or to low.
Once you start modifying the basic system (underdrive pullies for example) you're on your own ... good luck finding an alternator that produces the right amperage/voltage to keep the PCM happy.
I dropped 10k in engine mods and external mods from MTI in Houston, Tx. They suggested this was a better alt. for me since my vette has such a big cam lope at idle.
I just go with what I have been told, I am no electrical engineer. The last 3 or 4 times I drove it I did not get a HIGH VOLTAGE on the DIC, only Service TCS, Service Active Handling and Service Engine Soon.
So I guess Your sayin I need to go to GM and buy a 110 amp 14 volt alt now correct?
As for amp rating, it doesn't matter if you install a higher amperage rated alt, voltage regulation is a different control loop.
The sense wire is which one on the alt.? (should be the lower pin on the 2 pin connector, neg lead to any ground)
Sense wire?
You are talking about the plug w/ seal around it that is on the top of the alt.? Mine has 3 pins, not 2. This one is on the plug that is fixed to the internal rectifier on the alt.
I want to start testing this stuff over the weekend but am a bit confused on the sense wire and where to test from. hence the vette is idling or with the vette completely off w/ no key in the ignition.
Possible there is a diagram or pic of this wire?
Thanks,
Darrell
RIP Stevie Ray
Good luck
http://forums.corvetteforum.com/show...767&highlight=
Hooked up red lead to B+ on alt. and black lead to battery neg. terminal. Set it to min/max auto sensing dc voltage. Fired the vette up and it read a max of 14.5 vdc and a minimum of 14.39 vdc, average of 14.4 vdc.
I turned on ac, rear defogger, headlights while it was running, the read out on the multimeter dropped 0.2 vdc only
Got in the vette and looked at the DIC battery voltage while dmm was reading in the 14's, and my DIC read from 12.9 to 13.4 vdc.
Why the difference in readings?
I read from positive on battery to all the grounds I could reach, they read the same as the battery did from terminal to terminal.
This alt. is charging great in real time it seems? right?
Good Luck
Called the dealer where I bought it (Monument Chevrolet), and they sent a long flatbed wrecker. Did not hurt the vette... **whew*
Their vette tech found that the positive cable that goes to the starter was exposed to heat so many times from being close to the header tubes had become burnt and was brittle. They had to drop the header down on that side to replace it correctly. He replaced it with a thicker cable and added some heat shielding around it and reinstalled the header.
No more codes! Charging at 14.85vdc at the alt. and 14.5vdc on the DIC. With the ac, rear window defroster, radio, wipers and headlights on it is charging at 14.4vdc on the DIC. That 145 amp alt. is quick to adjust the voltage when needed. Had a new belt installed as well.
He also found a bad passenger side door module (computer?) that was bad. Had a problem with unlocking that door. He cleaned both right and left door wiring connectors, as well as bcm and pcm connectors.
With the GMPP, I was out of pocket $100.00 deductable plus $8.00 tax on a 2009 Pontiac G6 GT rental car. They even detailed it for me.
I pick it up Tuesday because of Hurricane Gustav, possible Wednesday if the rain has done any flooding.
Thanks for all your help,
Cross my fingers!
Darrell
You can't take the cables for granted.
Thanks for posting your fix, it will help others..
Good Luck
