Which Fuse?
Old Aug 23, 2008 | 05:50 AM
vettpapaw's Avatar
vettpapaw
Default Which Fuse?
What fuse do I need to pull to turn off DRL's? Will it effect anything else? Thanks
Old Aug 23, 2008 | 06:17 AM
paullywalnuts's Avatar
paullywalnuts
If I remember correctly its the #2 fuse in the fuse box near the battery..Check the manual if you have it..the only thing it affects when you disable DRL's is that the signals wont flash when you lock/arm the car with the fob. Good luck.
