A/C Schrader Valves Leak
Old Aug 23, 2008 | 02:57 PM
C5TORCHED's Avatar
C5TORCHED
Default A/C Schrader Valves Leak
I tried adding freon to the A/c system and the freon actually leaked out of both schrader valves. I tried pushing on the valves a couple of times to try to reseat them, seemed to help but I dont think it worked. Are there O-rings that can be replaced inside the valve?
Old Aug 23, 2008 | 04:06 PM
HOOBS's Avatar
HOOBS
Those valves have the same type as valve stems on your tires....You'll need to recover your freaon (empty) and take out the valve stems (shrader) valves and replace them...yes they hace o rings but they are very very tiny.
Old Aug 23, 2008 | 05:01 PM
C5TORCHED's Avatar
C5TORCHED
If they are similar to the tire valve stems, then I think the o-ring(s) are actually on the valve itself. Then the 2 shrader valves have to be replaced?
Old Aug 23, 2008 | 11:21 PM
HOOBS's Avatar
HOOBS
yep! But like I siad you'll have to make sure you recover any lost freon.....I would take it to a shop or maybe a hvac guy
Old Aug 24, 2008 | 03:30 PM
c5streak's Avatar
c5streak
Have you tried tightening them? Same tool as for tire valve stems will work. The schrader valves screw in just like on a tire. Tightening can fix the leak sometimes, and is way cheaper than evacuating the system to change a .50 cent part.
Worth a try.
Old Aug 24, 2008 | 07:07 PM
byronhunter's Avatar
byronhunter
Worth a try.
c5streak got it exactly right, also putting a good cap on kinda snug will help alot.
To A/C Schrader Valves Leak
