Got a "problem".....? Advise plz!!!!
Old Aug 23, 2008 | 03:12 PM
nightman06's Avatar
nightman06
Default Got a "problem".....? Advise plz!!!!
Im not sure if this is really a problem but it doesn't seem right to me. Im getting a sort of chugging sound when I get on the gas from low RPM's. Its clearly under the hood. I almost want to say its like a sewing machine but I dont want to mislead anyone into thinking its typical. I has all stock internals. Im not sure if it could be an exhaust leak but its like I can hear straight into the engine block. I cant hear whether it goes on higher than about 3K cause its drowned out by my exhaust. It makes my car sound like a beat up '80s Crown vic or something. Help please.
Old Aug 23, 2008 | 04:03 PM
HOOBS's Avatar
HOOBS
I had that problem with my 96 coupe and it turned out to be the fuel regulator.....your symptoms are exact as mine....I dont know if the c-5 has that.....just my 2 cents
Old Aug 23, 2008 | 04:18 PM
nightman06's Avatar
nightman06
What about the fuel regulator made that noise? I am not noticing any drop in power, or surging. Oh and just to make it more clear. This is only noticable when I am at low rpm's in a higher gear. For example. If I were driving at 30 mph and put it in 4th and hit the gas I would hear it. Almost like a muffled clicking sound. I cant be the first out there to have this....
Old Aug 23, 2008 | 04:30 PM
paolo's Avatar
paolo
Sounds very much like pinging to me... high gear and low rpm is when it normally happens.
Old Aug 24, 2008 | 05:24 PM
nightman06's Avatar
nightman06
Any other thoughts. I did some research on pinging and setup a tune. I recently had headers installed and have not yet had it tuned....possible culprit....?
Old Aug 24, 2008 | 05:31 PM
byronhunter's Avatar
byronhunter
Recently had headers installed????--Check for exhaust leak.
Old Aug 24, 2008 | 08:08 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Try pulling the codes and see if anything shows up there. PCV valve?
Old Aug 25, 2008 | 09:07 AM
jovette's Avatar
jovette
Did you notice this 'chugging' sound only after the header install? If yes, I suggest you check for exhaust leak between header and your heads.
To Got a "problem".....? Advise plz!!!!
