Wheel alignment data question
Old Aug 25, 2008 | 10:50 AM
50th in the 49th's Avatar
50th in the 49th
Default Wheel alignment data question
I had a 4-wheel alignment done in conjunction with new tires being installed this weekend. To show what a great job they did , the dealer provided me a print out of the data from their alignment system showing what the final numbers were after the alignment. The problem is, it appears many of the parameters are out of the specified range, at least according to the print out. Unfortunately, I'm at work right now, so I can't upload an image of the entire document, but for instance:
For the "Thrust Angle", it shows:
"Actual" of 0.13 degrees
"Specified" of -0.10 degrees
"Range" of 0.10 degrees
Now obviously, if nominal is "negative" 0.10 degrees and the actual was "positive" 0.13 degrees, that is out of tolerance.
I'd like to have some answers in my pocket before I call the dealer about this one. Any technicians out there that can help?
Old Aug 25, 2008 | 01:00 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
Hey Pete, last time I had an alignment done, my data sheet had several sets of numbers, including "before" and "after" measurements. Any chance you have something similar?
Old Aug 25, 2008 | 01:45 PM
TEXHAWK0's Avatar
TEXHAWK0
I would be most concerned about too much negative camber, and the toe-in setting. What were those numbers?
Be aware that, the camber can be "within factory specs", and still be too aggressive for street driving and acceptable tire wear.
Much more than about -1/8 degree on the front, and you will see inside tire wear.
Old Aug 25, 2008 | 03:13 PM
orpha's Avatar
orpha
you are ok, don't fret about it.
Old Aug 25, 2008 | 04:33 PM
50th in the 49th
Sort of. There is an "Actual" and a "Before" column, but conveniently enough, there is no data at all in the "Before" column.
Old Aug 25, 2008 | 04:47 PM
50th in the 49th
Kind of hard to see, but here is an image of the data. Testing to see if it is viewable on here or not.
Old Aug 25, 2008 | 05:23 PM
B-ras's Avatar
B-ras
IMO, I wouldn't pay for an alignment unless I saw before and after #s. How do you know they did anything at all?
Why is the LR toed out and the RR toed in? (Or is that vice-versa?) In any event, that doesn't look right to me. The range is the same for both, and they are WAY off.
Old Aug 25, 2008 | 11:32 PM
50th in the 49th
Well, the reason I did it was uneven wear on the original (I think; unless the previous owner changed them) run-flats.
I'm hoping that the data is the "as-found" numbers. The guy that does the alignments was off today, so I couldn't get an answer.
Old Aug 26, 2008 | 10:05 AM
waktasz's Avatar
waktasz
Nearly 0 camber all around? Ew.
Old Aug 26, 2008 | 02:01 PM
art43's Avatar
art43
Cruising
I found that an alignment done with the normal people IN the car and at GM spec work best.
To Wheel alignment data question
