Fuel filter?
Old Aug 25, 2008 | 06:16 PM
c5Cruiser's Avatar
c5Cruiser
From: Corona CA - "An Armed Society is a Polite Scociety"
Default Fuel filter? "We don't need no stinkin Fuel Filter!"
I know that my 98 has a fuel filter. I just can't find it.
I've looked where it's supposed to be but I still can't find it.
Any of you have the same problem? :o
Old Aug 25, 2008 | 06:38 PM
byronhunter's Avatar
byronhunter
Inside left frame rail, rear of car, even with transmision.
Old Aug 25, 2008 | 07:34 PM
c5Cruiser's Avatar
c5Cruiser
Thanks. I'll have to lift her and look again. I didn't see it the first time so I started digging in the engine bay and around the tank and went back to the frame area. I guess I missed it twice.:o
If any one has any pics I would be greatly appreciated.
Old Aug 25, 2008 | 07:39 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Just so I'll be straight on the understanding, that location is for all C5's, and that left side is driver side? Thanks.
Old Aug 25, 2008 | 07:48 PM
JAY KOCH's Avatar
JAY KOCH
NO!!!!
The location described above is for 1997 and 1998 models only. 1999 and newer have filter IN the fuel pump assembly.
The left side IS the driver's side.
Old Aug 25, 2008 | 08:14 PM
renegad44's Avatar
renegad44
^ Thanks, that's the info I needed.
Old Aug 25, 2008 | 08:22 PM
rbrtclk's Avatar
rbrtclk
Originally Posted by JAY KOCH
NO!!!!
I have a 2002 Vert and the fuel filter is not in the tank. it is a separate item with a fuel regulator built into it. Mounted under the car somewhere.
Old Aug 25, 2008 | 09:57 PM
bglmn's Avatar
bglmn
...one more little tidbit: If you're gonna replace it, put the
car on a lift. It's a real easy job with a lift.... a real difficult one without a lift.
Old Aug 26, 2008 | 02:57 PM
rcknusa's Avatar
rcknusa
Using the lift the second time I changed a fuel filter made the job much easier and quicker.
Old Aug 26, 2008 | 03:07 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
That somewhere is the same place as the others. It is on the inside frame rail just around the corner from the drivers side tank in the tunnel near the transmission. 10mm bolt holds the clamp and the clips will collapse and release the lines with your fingers. Be sure and relieve pressure at the rail, wear goggles and put your cigarette out when doing this job.
Old Aug 26, 2008 | 05:14 PM
BlackZ06's Avatar
BlackZ06
NO!!!!
Jay,
The filter can be in 2 different places on a C5 ..... 1997 into early 2003 Model Year the filter is in the rear on the left frame rail. Even within this range, early cars (1997 and 1998) it is the filter only while later cars the filter and pressure regulator are integrated. Starting in 2003, if the car has RPO FFS, then the filter has been moved inside the tank.
And .... NO ..... the left side is not neccesarily the driver's side ....
http://www.corvette.com.au/
This is one of several companies that convert Corvettes (and other vehicles) to Right Hand Drive (RHD) configuration. There are several members of this forum who have RHD vehicles in places like the UK (DeeGee) and Australia.
Old Aug 27, 2008 | 08:11 PM
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
http://forums.corvetteforum.com/show...ht=filter+fuel
Old Aug 27, 2008 | 11:04 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
NO!!!!
I'm the guy with the high mileage '99 that I recently gave away to my son. I changed the fuel filter on it several times over the years and I can verify that it was not in the tank, rather where others have noted it being on the driver's side adjacent to the tranny.
Old Aug 28, 2008 | 12:02 AM
lucky131969's Avatar
lucky131969
NO!!!!
Not true sir. That location is correct for 1997-2002 for sure. What's really goofy about your comment, is that your sig says you have a 1999, and you don't even know what's on your own car, yet you give the wrong advice to someone else with such conviction..
To Fuel filter?
