I'm having a problem with the radiator drain plug on my 2003 vert. Every drain I've ever come across has wings that you can easily grab to turn to allow the water to drain. I look at my drain and it has nothing to grab..it also isnt a nut that you would put a socket on..It looks original and doesn't appear damaged..I feel really dumb but just wondering if i'm missing something real easy.
Not dumb, but it has been asked/answered many times. Normally, I'd suggest you try to use search this forum (in the red banner) in C5 tech, but you'd probably have troubles with this new software.
On a positive note, I just tried using keywords "radiator drain plug" and came up with quite a few past threads. This is one of them that might help you... http://forums.corvetteforum.com/show...tor+plug+drain
The drain is designed to be removed with a 1/4" extension at the end of a ratchet. Turn it CCW and it will start to drain, but very slowly. Don't force it or you'll have to buy a replacement.
You can remove it completely at that point if you want faster drainage.
Only turn it 90 degrees, then you can pull it out. If you turn it more, you will shear the pin(s), and need a new one. NAPA sells them for $5 and they have "wings" on them so you can turn them by hand.
Also make sure your car is level to drain the most coolant from it.
The drain plugs are made where the right sized allen wrench or a 1/4" drive will fit the opening.
IF it has never been loose, you may have to carefully use pliars on the outer ring to keep from rounding off the inside hole. It also helps to be able to wiggle the plug a little while turning and lightly pulling.
When I drained mine, I turned 90 degrees and nothing happened- I tried pulling, nothing came out, repeated about 5 more times until I broke it. Now I have a replacement from Advance Auto with a place to grab an turn.
Thanks to everyone for the info. I replaced the drain with one that has wingtabs..Advance Auto Five Dollars..Best money That i ever spent..Turns real easy.
