Turn signal bulb failure
Old Aug 25, 2008 | 08:11 PM
R Devil's Avatar
R Devil
Default Turn signal bulb failure
I'm getting the rapid clicking noise when I turn on the right turn signal. It seems that one of the bulbs has failed in the front. (first one in 10 years) I don't see any screws holding the lense.
98 Coupe
Removal tips would be appreciated. TIA
Old Aug 25, 2008 | 10:07 PM
lionelhutz's Avatar
lionelhutz
Did you try a search????
http://forums.corvetteforum.com/show...nal+front+bulb
Took longer to copy the links than find them.
Peter
Old Aug 25, 2008 | 10:36 PM
R Devil's Avatar
R Devil
Old Aug 25, 2008 | 11:44 PM
jrose7004's Avatar
jrose7004
Come at it through the access panel underneeth!
Old Aug 26, 2008 | 05:37 AM
sikpuppy's Avatar
sikpuppy
St. Jude Donor '08
Or if you have skinny hands you can just push the air vent to one side and reach around it and take out the bulb. If it has been ten years though, the top of your housing is most likely cracked from the bulb's heat and will need to be either replaced or repaired. If you don't, the first little amount of water that gets in there will find it's way through the cracks and shatter the bulb again!
Good Luck!!
Old Aug 26, 2008 | 07:53 AM
rws.1's Avatar
rws.1
3 approaches that depend on the length and girth of your forearms
1. long thin arms ... raise the headlights, remove the black plastic bezel around them reach in and down to find the bulb... standard socket .. depress the locking tab and turn to remove
2. short thin arms ... push in on the brake duct,, it is basically a plastic accordion tube, then push it down and out of the way . Reach in and up to find the bulb.... depress and turn.
3. thick arms.... put the car on ramps or jackstands remove the acess panel from below about 5 6 (or 7) mm screws. you will have clear access to the direction signals and fogs lights.
If the bulb burn out again shortly then you have the notorious cracked or leaking housing syndrome.
Old Aug 26, 2008 | 08:27 AM
hayman's Avatar
hayman
Don't mean to hijack but, Mine has blown again in a matter of a year, (right side). The bulb was not shattered, What else can be blowing it?
Bill
Old Aug 26, 2008 | 12:38 PM
R Devil's Avatar
R Devil
Couldn't reach it so I removed the lower panel. Replaced the bulb and it's working again.
Thanks for the replys.
Old Aug 26, 2008 | 12:58 PM
TEXHAWK0's Avatar
TEXHAWK0
Bill
Have you checked the housing to see if there is water getting in on the bulb? It seems fairly common for housings to develop cracks from the heat of the bulb.
Old Jun 29, 2009 | 03:18 PM
Blue LS1-LT1's Avatar
Blue LS1-LT1
Originally Posted by 8VETTE7
A little moisture can cause a premature end to the bulbs.
After a rain soaked, flash-flooded, ponding, 125+ mile drive back home from track day at Pocono, the passenger side turn signal on my '99 went out.
Makes me wonder if the culprit is age (10 years, 52,000 miles), or water intrusion. I drive the car in the rain if left with no choice, but, nothing like I saw the other day. It was really coming down.
I've changed the driver's side fog light twice by going in behind the headlight bezel, so this shouldn't be too bad??
Old Jun 29, 2009 | 06:56 PM
NavyDoc2007's Avatar
NavyDoc2007
Now's the perfect time to upgrade to clear corners and LED bulbs. Then you should be set for more than another 10 years...
Old Jun 29, 2009 | 09:28 PM
Blue LS1-LT1
Perhaps. Would need to research and learn about...
Just to please clarify this second look-test by me this evening:
There is no light or flashing with hazards or right turn signal, passenger side.
The only light that works on the passenger side is the parking light which illuminates the side AND the front of the corners.
If I turn off the parking lights, the passenger side gets no light activity.
Does that make sense?
Does this mean the failure is the DLR bulb only, one filament? Someone mentioned in this, or a related post, the DLR bulb is a double filament bulb.
Old Jun 30, 2009 | 06:45 PM
lionelhutz's Avatar
lionelhutz
Yup, makes sense. Most likely the bulb. It is a dual filament and since the signal/DRL filament is the one on most of the time it is the one most likely to burn out. You need to test/change the bulb before convincing yourself there is a bigger problem.
I blew 3 or 4 bulbs during the summer when my housing cracked. Yes, I drive in the rain. I put the black outlined corner lights in the car. The completely clear ones seemed too plain to me. Look on that huge auction site for Depo C5 lights and you should find a few styles.
Peter
Old Jul 1, 2009 | 01:16 AM
zwaldo's Avatar
zwaldo
LED beware. I just put Led's in my turn signals because the orange had cracked off my lights. The leds work fine, BUT one thing. The turn signs now click super fast like a bulb is out, probably because of the diffrence in watts being used....So I guess i'm going to switch the amber leds with the drls tomorrow. But i'm currently researching the led problem.
Old Jul 1, 2009 | 11:57 AM
Blue LS1-LT1
I am experiencing this problem for the first time.
What I've read so far, is that if you swop out the stock bulbs to LED's, the wire harness must be changed too. The new harness prevents the fast flash problem you are now getting.
Old Jul 1, 2009 | 01:50 PM
97C5owner's Avatar
97C5owner
HATE swapping those darn things out. Like playing a bad game of Twister to get at em!
Old Jul 1, 2009 | 04:06 PM
my6thvette's Avatar
my6thvette
Just changed mine this morning. Went in through the bottom.
To Turn signal bulb failure
Old Jul 2, 2009 | 12:33 AM
lionelhutz's Avatar
lionelhutz
The C5 flasher is actually a sophisticated piece. If the load on this flasher is reduced it will flash faster. This is supposed to warn you of a failed bulb. However, it creates a problem when LED's are used. This is the DIY fix.
http://forums.corvetteforum.com/1569256474-post64.html
There is a pre-made harness available that also does this. Hopefully someone can post up a link to it.
Peter
Old Jul 2, 2009 | 01:03 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
We have LED upgrades for the DRLS. We offer them in the switchback, amber, or white. We even have the housings available.
http://www.shop.jwmotoring.com/category.sc?categoryId=4
I also can point you in the right direction for the flasher harness.
Old Jul 7, 2009 | 10:02 AM
Blue LS1-LT1
I replaced passenger side this weekend. Took 15 minutes, tops.
I found a combination of going in throught the brake air duct, and also, down past the manually raised headlight with removed bezel worked for me.
As someone mentioned, you only need to nudge the accordion shaped portion of the brake duct down and away. The socket is right there above.
From there, twist the socket as discussed earlier, and gently pull the harness out, change the bulb, and replace.
I found once I tested the new bulb, it's easier to lock the thing in place going in from the top.
I wore rubber gloves to keep the oil on my fingers off the bulb.
