HUD conversion ??
Old Aug 26, 2008 | 12:30 AM
97C5owner's Avatar
97C5owner
Default HUD conversion ??
Is the 11 pin harness from the HUD control panel the same as the ones on the sides of the instrument cluster or the information switch? Can they be used interchangeably? They look very similar.
Old Aug 26, 2008 | 08:13 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
you need a new 11pin end w/ the wires; contact pacethis
Old Aug 26, 2008 | 11:44 AM
97C5owner's Avatar
97C5owner
So they're not the same??
Old Aug 26, 2008 | 12:00 PM
sprinter1104's Avatar
sprinter1104
No they are not.
If you currently have the standard dimmer switch (without any of the hud functions) then your current harness has the same plugs but fewer wires. You'll need the hud harness if you are going to install the hud switch.
I Hope this helps.
Old Aug 26, 2008 | 03:01 PM
Chevy Guy's Avatar
Chevy Guy
Check EBAY, they are often for sale there, some can be pricey though.
Old Aug 26, 2008 | 05:12 PM
LoneStarFRC's Avatar
LoneStarFRC
I've got something I think may help you out John. I'll call you.
To HUD conversion ??
